Ethernet Gadget on MacOS
andrewvit
Post by andrewvit »
I'm not having any success following the guide for connecting to my Pi Zero (non"-W") using USB/ethernet gadget mode.
I imaged Raspbian Lite (buster) using Raspberry Pi imager, and configured according to:
https://learn.adafruit.com/turning-your ... net-gadget
It looks like the OS boots correctly and puts me at the login prompt, which I can see when I connect an HDMI cable. I can see the `g_ether` module being loaded and configured. I also tried adding the various recommended module options to the cmdline.txt script including static addresses, too:
modules-load=dwc2,g_ether g_ether.host_addr=11:22:33:44:55:66 g_ether.dev_addr=66:55:44:33:22:11 g_ether.use_eem=0
However, I'm unable to see the device show up on the host machine, and cannot SSH to it. In Network Settings there is no "RNDIS/Ethernet Gadget".
For what it's worth, the Pi is not receptive to normal USB input if I try to boot it standalone and plug in a keyboard so I suspect it's doing the right thing and setting up the USB as an ethernet adapter.
I'm running MacOS Catalina: is this known to be supported there, or does it need to have HoRNDIS installed separately? (This is not documented and it sounds like it should just work without it.)
Does anyone know if the guide I'm following is up to date, or anything else I might be missing? Any tips or help appreciated. Thanks!
mikeysklar
Re: Ethernet Gadget on MacOS
Post by mikeysklar »
Can you post a photo of how you have the Pi connected? I really just want to make sure you are going into the micro USB connect with the ethernet gadget.
If you manually tried to load the module after boot do you see the USB device?
modprobe g_ether host_addr=00:11:22:33:44:55
Check for usb0 device using
ifconfig -a
andrewvit
Post by andrewvit »
Thanks for the response. I tried imaging the SD again, and booting without any config changes.
After doing both `sudo modprobe g_ether` and `modprobe dwc2` I can only see the loopback device under `ifconfig -a`. No usb0.
This is my connection. The grey microUSB has USB-A on the other end, into the USB-C adapter, which I plug into to the MacBookPro host machine. This cable works for programming Arduino, so I believe it should work here too.
Screen Shot 2021-09-23 at 1.39.41 AM.png (903.31 KiB) Viewed 1295 times
mikeysklar
Don't forget to plug in the USB cable from your computer to the "USB" connector port on the Pi Zero, not the PWR connector.
Based on the photo provided and the note from our guide above it looks like you need to be on the Pi Zero micro-USB port (not the micro-USB power port) with your data cable.
andrewvit
Post by andrewvit »
Yes, I thought that's what I had: unless these are labelled incorrectly?
Screen Shot 2021-09-23 at 7.45.28 PM.png (677.95 KiB) Viewed 1279 times
It lights up the LED and boots up when plugged into this port marked "USB" using a data cable. It also boots when powered standalone from the port marked "PWR". I'm not sure if the ports are interchangeable in that case, I haven't tried to swap them around yet.
mikeysklar
micro-USB port looks good. Thanks for the close up shot.
There is a short RNDIS setup guide here that is not ours, but is MAC specific and might be helpful to try.
https://gist.github.com/superdodd/06b91 ... 8b27dc601e
andrewvit
Post by andrewvit »
There is a short note on this page, which makes me wonder if it can even work on a Pi Zero if the board doesn't have its own ethernet:
due to the lack of built-in Ethernet on the board, you will either need a USB Ethernet adapter that you can use to configure the Pi, or a Serial-to-UART cable.
https://www.instructables.com/Set-Up-a- ... ing-a-Mac/
mikeysklar
No people are doing this with the Pi Zero no USB or UART cable.
Try the 'superdodd' github link I sent and see if / where that fails. It is Pi Zero based.
