Hi
I purchased a Raspberry PI 4 a couple of months ago and I have been having constant problems with it since the beginning which I was blaming on the OS. Now after extensive troubleshooting I realize that the ethernet card is the problem.
The issue I am having is that ethernet loses connection every 3 minutes or so and after a few seconds it regains it the connection on its own.
Here's what I know:
1) If I connect via WIFI it does not disconnect.
2) If I remove the SD card with the OS and plug it into another raspberry Pi 4, ethernet works flawless.
3) The issue happens at home and at work, so it is not related to my particular network setup.
Can anybody help?
Thank you
Raspberry PI 4 disconnects from network every 3 minutes.
- mambi00
- Franklin97355
Re: Raspberry PI 4 disconnects from network every 3 minutes.
What are you using to power it? The pi4 sucks a lot of power and could overload the supply. Just checking.
- mambi00
Hi, thanks for answering
I am using one of the best power supplies for the Raspberry Pi 4, the Argon 1, with 18W and 3.5A. I use the same power supply on another PI with the same SD card and I have no issues with the Ethernet card.
- Franklin97355
OK, you can contact [email protected] with a link to this thread and you order number and they will get you a different pi 4.
- mambi00
Thank you so much.
