Using image "ImageFont.truetype('/usr/share/fonts/truetype/dejavu/DejaVuSans.ttf',19)" we can increase the font size but when we have to refresh data we had to paint the entire image. Is there way to increase the font size when we just use OLED.text(x,y,"text",fill)
Thanks and Regards
Sarang
Adafruit PiOLED - 128x32 Monochrome OLED HOW TO INCREASE FON
- stirucherai
- stirucherai
Re: Adafruit PiOLED - 128x32 Monochrome OLED HOW TO INCREASE
Solved it -- it is all working
- mikeysklar
What was your solution?
- stirucherai
1. Had two fonts declared.
2. draw.rectangle((0, 0, width, height), outline=0, fill=0) had this statement for every refresh of data
Attached the full code which is used for display -- now it works perfectly. Now got 2.23 inch PIOLED 128*32 (same size as this mini) and the same code works perfectly (just that we need to change 1306 to 1305 - 3 places)
from board import SCL, SDA
import busio
from PIL import Image, ImageDraw, ImageFont
import adafruit_ssd1306
i2c = busio.I2C(SCL, SDA)
disp = adafruit_ssd1306.SSD1306_I2C(128, 32, i2c)
disp.fill(0)
disp.show()
width = disp.width
height = disp.height
image = Image.new("1", (width, height))
draw = ImageDraw.Draw(image)
fontB = ImageFont.truetype('/opt/vc/src/hello_pi/hello_font/Vera.ttf',19)
fontS = ImageFont.truetype('/opt/vc/src/hello_pi/hello_font/Vera.ttf',11)
def displayData(soc, voltage, current):
draw.text(( 0, 6), str("{:6.2f}".format(soc)) +"%", font=fontB, fill=255)
draw.text((75, 0), str("{:8.2f}".format(voltage)) + "V" , font=fontS, fill=255)
draw.text((75,16), str("{:8.2f}".format(current)) + "A" , font=fontS, fill=255)
disp.image(image)
disp.show()
import busio
disp.fill(0)
disp.show()
width = disp.width
disp.image(image)
disp.show()
- stirucherai
Attached photo - for both mini PiOLED and 2.23inch PiOLED
- Attachments
- piOLED.jpg (432.46 KiB) Viewed 95 times
- mikeysklar
That Vera font looks good. Thank you so much for sharing the code and pictures. I'm sure this will help others.
