B+ Pi, 64x64 led-matrix, matrix bonnet, power supply
- Berrtt
I'm trying to load and run either python, c, on my rasbarry but I can't seem to figure out the correct procedure. It keeps telling me commands aren't found, such as: make, and cd~ Are there any good videos that show the process, or any help is much appreciated.
- adafruit_support_carter
Re: B+ Pi, 64x64 led-matrix, matrix bonnet, power supply
The main guide for the Matrix Bonnet is here:
https://learn.adafruit.com/adafruit-rgb ... spberry-pi
Are you trying to follow that?
- Berrtt
Yeah I've followed that and got my pi configured and I believe updated but I'm just confused on checking if everything is correct, loading code, write to the rasbarry, and accessing the terminal. I was looking at another post and read about the online ide would this work?
In general, you want to run commands from the Pi's command line as shown here:
https://learn.adafruit.com/adafruit-rgb ... 2982010-30
If you have a monitor/keyboard attached to the Pi, can open a shell directly.
If you do not, then can ssh into the Pi.
