Can't get the script to install the "Adafruit PiTFT 3.5" Tou
poppabear
Post by poppabear »
Can't get the script to install the "Adafruit PiTFT 3.5" Touch Screen for Raspberry
I get to the part where I pick what size screen (35r), and orientation (270).
But then I get this error after the first two PITFT commands run.
Here is what is on the command line interface:
PITFI Checking init system...
Found systemd
/boot is mounted
PITFI System Update
Updating apt indexes...............
PITFT Apt failed to update indexes! <<<<<fails here!!!!!!
~/Rasberry-Pi-Installer-Scripts $ <<<<<back to command line
NOTE: I am running Octopi (for a 3D printer) 3B+ board, and wanted to add the Touch Screen running the "TouchUI" plugin.
Any clues on how to get past this, so I can use the screen?
I did/have followed the install instructions on your website for the PiTFT 3.
adafruit_support_carter
Re: Can't get the script to install the "Adafruit PiTFT 3.5"
May be Octoprint related.
Does it work OK using Raspberry Pi OS?
https://learn.adafruit.com/adafruit-pit ... -2986641-4
You'll need to start with Raspberry Pi OS or Raspberry Pi OS Lite.
poppabear
Post by poppabear »
well, I need the Octopi since it runs the 3D printer,
If I did load those images, and then tried to upgrade to Octopi,
it would again fail since the octopi is an image as well.
Again, the octopi is dedicated to/for a printer.
Is there anyway somebody on the ada team could look in to this?
there are many in the 3D world that used the Octopi, and they could
all use a local display for local machine ops.
thanks for your time, if you can help, or someone can help,
I am sure it is just some kind of "Script" issue, but again my Octopi
is on python2, but I upgraded the "git" to python 3 (I think), since it was
part of the install script from your website.
NOTE: I am NOT any kind of Raspberry guru, just use them for the printing.
