MAX98357 issues
jk3ger
MAX98357 issues
Post by jk3ger »
Hello, I'm using board with MAX98357A chip and Raspberry Pi 4 model B.
I followed examples on this link https://learn.adafruit.com/adafruit-max ... y-pi-usage
After rebooting I see BCLK and LRCLK signals on oscilloscope but there is no DOUT pulses (only zero logic level) from GPIO21 of Rasberry. As a result there is no sound from speaker.
I tried Raspberry Pi CM4 board with IO Board but result the same.
So, Do you have some ideas how It can be fixed.
adafruit_support_carter
Re: MAX98357 issues
What OS image are you using?
Did you see any errors when you ran the install script?
jk3ger
Re: MAX98357 issues
Post by jk3ger »
There is no errors. Everything goes as it described in adafruit manual.
pi@raspberrypi:~ $ cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
NAME="Raspbian GNU/Linux"
VERSION_ID="10"
VERSION="10 (buster)"
VERSION_CODENAME=buster
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
Re: MAX98357 issues
Thanks, that should all be fine.
Were you using the Fast Install or the Detail Install approach when setting things up?
Can you post a photo of your setup so we can look for anything that might be wrong with the hardware.
jk3ger
Re: MAX98357 issues
Post by jk3ger »
Thanks for attention.
Everything is solved.
After second rebooting I re-ran the script and choose N the /dev/zero playback service.
Than sudo reboot and after that i2s started working.
