I am using the adafruit servokit library to drive servo motors from python3,
I am running into a problem where I am getting this error:
" ModuleNotFoundError: No module named 'board' "
I have installed the blinka library, but that has not seemed to help
if I install the board library (sudo pip3 install board), then the error I get is
" AttributeError: module 'board' has no attribute 'I2C' "
What other troubleshooting options could I try to fix this problem?
ServoHat Driver
- adafruit_support_carter
Re: ServoHat Driver
This is not the fix. That is a totally unrelated Python package. See here:if I install the board library (sudo pip3 install board), then the error I get is
https://learn.adafruit.com/circuitpytho ... aq-3055911
Use the test here to make sure the Blinka install is OK:
https://learn.adafruit.com/circuitpytho ... 3030038-17
- ilanfelberg
Re: ServoHat Driver
Thank you!
I tried the force reinstall of Blinka as suggested, and I was able to work through the problem from there!
