Programming Capacitive Touch Sensor in Python 2.7
satre
Post by satre »
Hi! I have the momentary capacitive touch sensor, https://www.adafruit.com/product/1374
I also have an old RPi2 that's running a 16x32 LED matrix with an old Adafruit LED Matrix Hat that runs beautifully with Python 2.7 and the old libraries that run it. I want to add the touch sensor to the project so that when you touch the sensor, an image is shown on the LED Matrix. Problem is, the tutorial for the touch sensor says to install Circuit Python and Blinka which needs a newer version of Python.
OK, so I tried updating, and I tried swapping in a new RPi 3B+, but the LED Matrix Hat is not functioning properly on the newer Python and associated libraries, and I spent 1/2 a day trying to troubleshoot (which I'm not really good at) and then just went back to the RPi 2.
Basically then... Can I use the touch sensor with the old Python? If so, how?
Satre
mikeysklar
Re: Programming Capacitive Touch Sensor in Python 2.7
Post by mikeysklar »
I don't know how to make this work without adafruit-blinka installed.
Since you have a Pi3B you can experiment with let's try and get the LED Matrix going first then move on to add the sensor.
What error were you getting stuck at with the LED Matrix?
