2823 Compatible with Pi Zero WH
- davdue
I am thinking about using the Pi Zero WH for a project and would like to use the https://www.adafruit.com/product/2823 0.1" 2x20-pin Strip Right Angle Female Header as a disconnect and solder my connections on the right angle header. Will it plug onto the male header on the Pi Zero?
- mikeysklar
Re: 2823 Compatible with Pi Zero WH
Yes, that will work using the right angle header on top of the default headers with the Pi Zero WH.
We have cobblers and breakouts that will also make it a lot easier to setup connections.
https://www.adafruit.com/?q=pi+cobbler&sort=BestMatch
https://www.adafruit.com/?q=pi+breakout ... =BestMatch
I find it really helpful to have the pin labels as it is easy to get off by one pin or confuse which column of header you are in.
