No Response From Joy Bonnet
- talofaholbrook
Re: No Response From Joy Bonnet
when i ctrl+c i get this message. so it seems to be running...
- Attachments
- PXL_20211120_041812911.jpg (808.8 KiB) Viewed 517 times
- adafruit_support_carter
That is the expected behavior. The code won't exit. It's looping forever reading the bonnet and emitting key presses as needed.
Let's now check if the script is actually running after boot. Run this to check that the script is set to run at boot:
and then run this to check that it is actually running:
Please post another photo of screen showing output from those commands.
cat /etc/rc.local | grep joyBonnet.py
ps -ef | grep joyBonnet.py
- talofaholbrook
Welp... now it's working all of a sudden. not sure what has changed.
- Attachments
- IMG_20211123_102345.jpg (297.14 KiB) Viewed 506 times
- IMG_20211123_102350.jpg (230.73 KiB) Viewed 506 times
- IMG_20211123_102354.jpg (257.99 KiB) Viewed 506 times
- talofaholbrook
Come to think of it... i did install some packages it was complaining about after the install script ran. Now that all the components are installed properly. it's running now properly at boot
Yep, looks good at this point. The rc.local file has the expected contents and the python script is showing up in the running processes. And you are getting keystrokes showing up.
Hopefully can just continue with rest of the guide now.
- talofaholbrook
It's good to go now. All is working. Thanks
