I am not able to get the 12 led neopixel led ring to work correctly with the new raspberry pi os 32bit bullseye.
I have the following command in crontab to run the script for the neopixel
@reboot python3 /home/pi/rpi_ws281x/python/examples/strandtest.py &
The neopixel starts a led pattern but stops
There is no issues when running this script on the previous raspberry pi os 32bit (not bullseye)
Appreciate any help
12 Led Neopixel Ring with new raspberry pi os bullseye os
- bobster316
- adafruit_support_carter
Re: 12 Led Neopixel Ring with new raspberry pi os bullseye o
Run the command interactively so you can check for any error message output.
- bobster316
Can you please advise how to run in interactrive mode ?
- bobster316
This is the ocnfiguration i have used
sudo pip3 uninstall rpi_ws281x
sudo pip3 install rpi_ws281x
sudo pip3 install adafruit-blinka
sudo apt-get install python-dev git scons swig
git clone https://github.com/jgarff/rpi_ws281x.git
cd rpi_ws281x
sudo scons
cd python
sudo python3 setup.py build
cd examples
crontab -e
@reboot sudo python3 /home/pi/rpi_ws281x//python/examples/strandtest.py &
I have noticed the leds atsrt after boot but then stop after approx 5 seconds.
When rrunning the script manuualy when the pi is already booted it works fine
cd rpi_ws281x
sudo scons
cd python
cd examples
crontab -e
- bobster316
Please see video which shows the issue
The Neopixel led ring is at the top of the inside of the case
https://youtu.be/Gnc3jYsElUE
At a command line, run the same command you are trying to run via cron:
and post any errors it produces.
- bobster316
pi@raspberrypi:~ $ python3 /home/pi/rpi_ws281x/python/examples/strandtest.py
Can't open /dev/mem: Permission denied
File "/home/pi/rpi_ws281x/python/examples/strandtest.py", line 91, in <module>
strip.begin()
File "/usr/local/lib/python3.9/dist-packages/rpi_ws281x/rpi_ws281x.py", line 131, in begin
raise RuntimeError('ws2811_init failed with code {0} ({1})'.format(resp, str_resp))
RuntimeError: ws2811_init failed with code -5 (mmap() failed)
Segmentation fault
pi@raspberrypi:~ $ sudo python3 /home/pi/rpi_ws281x/python/examples/strandtest.py
Press Ctrl-C to quit.
Use "-c" argument to clear LEDs on exit
Color wipe animations.
Theater chase animations.
Rainbow animations.
This worke until it reached the Rainbow animations.where it stopped
strip.begin()
Segmentation fault
Rainbow animations.
Did the code exit with an error message? Or it just printed the last line:
and never continued beyond that?
And what was happening with the NeoPixels? Did they continue to animate? Or stopped?
Rainbow animations.
- bobster316
There is no error i i cam see ? Would there be log file somewhere ?
No. If it's printing that and nothing else, then it seems like it's getting stuck in a loop somewhere. But there's nothing obvious in the code.
Do the NeoPixels continue to animate? Or do they also stop?
- bobster316
The Neopixel starts displaying a pattern of led;s seems a bit erratic and then stop cycling when reachinig the rainbow pattern of
the script
the script
Really weird behavior. There's nothing fundamentally different about the rainbow animations:
https://github.com/jgarff/rpi_ws281x/bl ... andtest.py
All the animations are using the same basic calls. So not sure why it would *partially* work on Buster.
Try rearranging the sketch to call the rainbow animations first. Does it still fail on those? Or does it do something different?
- bobster316
All i can say is this issue started when i started using bullseye, there must be some compatibility issue?
Are you starting with a fresh install of bullseye and then going through the install setup? Or did you upgrade an existing system to bullseye?
- bobster316
Yes thats what i am doing.
Is there someone i can speak to, messaging back and forth is not getting anywhere
