I am looking for a solution to power a RPi3B+ based project with a 7" Pi touch screen. I need to be able to switch seamlessly between wall power and battery. I need the battery to be at least 15Ah. I have the resources to make my own battery packs so I thought that a good solution could be a RPi UPS circuit. Does anyone out there have experience with a project using one of these? I have ordered a few for testing, but the first one that came in just doesn't work. I tested between the 5V and Ground pins using a commercial 3.7V LiPo battery pack and there is no voltage there at all.
Any suggestions? Does anyone know of anything that has worked for you?
Power a RPi3B+ with screen not using a USB power bank
- Steger21
- mikeysklar
Re: Power a RPi3B+ with screen not using a USB power bank
We use the PowerBoost 1000C in our 7" Pi MultiTouch Tablet guide. It uses a Pi 2 running on a LiPo pack.
https://www.adafruit.com/product/2465
https://learn.adafruit.com/7-portable-r ... uch-tablet
- Steger21
I ended up tearing open a Rav Power USB power bank that has passthrough charging and integrating it's components into my build.
- robersmithenton
The monitor can be powered by a 10W charger – it can be your regular USB-C smartphone charger or you can use the charging head provided in the box. You can even power it up using a power bank (provided your power bank outputs 5V / 2A)
