Hello, I received an order today and noticed the LED on ground is broken. Will this affect its function or should k be okay?
Broken LED on PCA9685
- adafruit_support_carter
Re: Broken LED on PCA9685
Looks like the image did not get posted. Is this the board you have?
https://www.adafruit.com/product/815
- blaravie
My apologies, yes that is the board.
- 63945624-885E-4112-B0DA-50FF4881CA50.jpeg (488.94 KiB) Viewed 329 times
Thanks. Is this the LED in question?
What is your indication that it is not working?- blaravie
Yes that’s the one
In general, the board should work fine without that LED. It is just a power indicator LED. It should come on when the board is powered via the VCC pin.
- blaravie
Okay so it won’t affect functionality?
Correct. It should not affect functionality.
The schematic for that board is available here:
https://learn.adafruit.com/16-channel-p ... /downloads
There you can see the LED is simply connected to power.
- blaravie
Great, thanks for the help!
- robersmithenton
Just for a quick test I've wired up the Arduino to a PCA9685 board (similar to http://www.ebay.com.au/itm/PCA9685-16-C ... Sw9ZdXKa7h) as follows
5v > Vcc & V+
GND > GND
A4 > SDA
A5 > DCL
OE > Not connected
I've wired a 1k resistor in series and an LED in between PWM0 and GND
The same LED dims fine when powered directly via PWM from the Arduino.
The power light on both boards come on and +5v is available at the V+ pins.
The library I'm attempting to use is https://github.com/kasperskaarhoj/PCA96 ... no-Library and from what I can tell the I2C address I've configured "works"
5v > Vcc & V+
GND > GND
A4 > SDA
A5 > DCL
OE > Not connected
@robersmithenton - These forums are for support of Adafruit products. We can't provide support for 3rd party boards or 3rd party drivers. Please contact the supplier of your board for technical assistance.
