Hello there!
Is it possible to simultaneously record audio through the board's microphones and output it through the JST 2PH connector?
I plan to use the board for a DIY intercom system.
Bortus
Adafruit Voice Bonnet - Input and Output at the same time?
- Bortus
- mikeysklar
Re: Adafruit Voice Bonnet - Input and Output at the same tim
Bortus,
Good question. I cannot say that it work to record and playback audio simultaneously. The datasheet and guide do not mention this scenario.
https://cdn-learn.adafruit.com/assets/a ... 1603825540
The input and output would all be going over i2s through the same CODEC.
You could try something like these command running at the same time.
Should playback be an issue you could use the Pi built-in 1/8" jack or HDMI audio output.
arecord --device=hw:1,0 --format S16_LE --rate 44100 -c1 test.wav
aplay -D plughw:1,0 test2.wav
- Bortus
Thanks for the reply!
So I tried the following command (bonnet needs to be the default device or otherwise specified):
This works. Everything that is being picked up by the microphones is played back throught the speaker.
arecord -f cd | aplay
- mikeysklar
oh cool, thanks for sharing the syntax to record and pipe the audio through a speaker.
