I apologize in advance if this is a question I could have answered by reading the docs.
I need to add an RTC to a raspberry pi in addition to a full HAT (specifically the Automation HAT). Could I combine the STEMMA shim with the STEMMA DS3231 breakout for an equivalent setup to the DS3231 PiRTC?
Adding an RTC through a STEMMA shim
- dastels
Re: Adding an RTC through a STEMMA shim
There's already an I2C expansion connector on the back of the hat. It's not stemma, but it looks like https://www.adafruit.com/product/4209 would do the job.
Otherwise, yes, a shim should work as long as it doesn't interfere with mounting the hat. HOWEVER, I put no faith in the way the shim connects to the pi header. It's friction fit and assumes no dirt of corrosion. Ok, sure, so does the I2C connection on the hat, but it's a connector designed to be a good connector. It has more connecting surface area and is spring loaded to create a snug grab of the inserted pins.
- facets
Good point about the friction fit. Since my application is pretty rattly, I'll just have to carefully solder the shim on, and the permanent addition of an I2C expansion won't be a tragedy. The HAT doesn't expand the I2C bus, though; that silkscreen text that happens to be near the GPIO header is just telling the user the address for the analog channels (the ADC chip is an ADS1015 or ADS1115, address 0x48).
- dastels
Doah! I was looking at the Automation Hat Mini.
Your approach sounds reasonable.
