Hello, I purchased an AIY vision kit and a AIY voice kit on JAN 14th. I assembled the voice kit with no problems, but the vision kit seems to have a faulty Pi zero.
The Pi zero in the vision kit does not turn on, I have tested the SD card and cable in the other Pi zero that I have, and that one works perfectly. The faulty Pi zero just gets hot when plugged in.
AIY Vision kit Pi zero wont boot, heating up
- Gmcnei02
- mikeysklar
Re: AIY Vision kit Pi zero wont boot, heating up
Thanks for testing with another Pi Zero. Please contact [email protected] requesting a replacement Pi Zero WH. Include a link to this forum thread and your order# in the e-mail.
- Gmcnei02
Thank you!
Is there a trick to getting the plastic posts out of the pi and the hat that are holding them together?
- mikeysklar
You should be able to squeeze the top of the plastic posts with a pair of needle nose pliers so they will flatten out. You can then lift the board one corner at a time onto the flattened tip.
