Hello Guys,
I am supplying the voltage 3.3 to the ADC from raspberry pi.
Gain = 1 mean (4.09V)
My question is
is it possible for me to measure the signal greater than 3.3V upto 4.09V on any channel????
I have read, its not possible to measure the signal greater than the supplied voltage to the ADC, which is in my case 3.3V
ADS1115 16 bit ADC
Re: ADS1115 16 bit ADC
No. It is not possible to measure signals greater than VDD. And any voltage higher the VDD + 0.3V is likely to cause permanent damage to the device.is it possible for me to measure the signal greater than 3.3V upto 4.09V on any channel????
(See section 7. Absolute Maximum Ratings)
https://www.ti.com/lit/ds/symlink/ads11 ... e.com%252F
- sj_remington
You can use a voltage divider to reduce an input voltage to the allowable range.
- AsifSaeed
If i apply 5V to the ADC, then i can measure the signal on any channel upto 5V. right????adafruit_support_bill wrote:No. It is not possible to measure signals greater than VDD. And any voltage higher the VDD + 0.3V is likely to cause permanent damage to the device.
Yes. However now the i2c signals will be pulled up to 5v also, so you will need an i2c level-shifter to protect the signal pins on your Pi. https://www.adafruit.com/product/757
The voltage divider solution suggested by sj_remington is a bit simpler.
- AsifSaeed
adafruit_support_bill wrote:Yes. However now the i2c signals will be pulled up to 5v also, so you will need an i2c level-shifter to protect the signal pins on your Pi. https://www.adafruit.com/product/757
great . Thank you for suport
