SDK for lobe does not load
Seaplane
Post by Seaplane »
Why does it fail and what is needed to correct the load on a Raspberry pi
The SDK can not be loaded and errors out on the numpy load. The error says:
build/lib.linux-armv7l-3.7/numpy/core/_multiarray_umath.cpython-37m-arm-linux-gnueabihf.so" failed with exit status 1
Failed to build numpy
ERROR: Could not build wheels for numpy, which is required to install pyproject.toml-based projects
WARNING: You are using pip version 22.0.3; however, version 22.0.4 is available.
You should consider upgrading via the '/usr/bin/python3 -m pip install --upgrade pip' command.
When I check my version of pip it is the latest version
pi@pi:~ $ pip --version
pip 22.0.4 from /home/pi/.local/lib/python3.7/site-packages/pip (python 3.7)
Also note the raspberry pi version
PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
NAME="Raspbian GNU/Linux"
VERSION_ID="10"
VERSION="10 (buster)"
VERSION_CODENAME=buster
mikeysklar
Re: SDK for lobe does not load
Post by mikeysklar »
Did this error come from the Installation of the Lobe SDK script?
sudo bash lobe-rpi-install.sh
Do you know which release of Raspbian Buster you are running (release date, 32-bit Lite vs Full Desktop)?
What is the output of:
sudo pip --version
