Adafruit DC & Stepper Motor Bonnet no output
billthefighter
Post by billthefighter »
I recently purchased 2x of the Adafruit DC & Stepper Motor Bonnet for Raspberry Pi PID: 4280 as well as a Pimoroni pHAT Stack for Raspberry Pi PID: 3742.
I am attempting to drive a 12v DC motor with a 12v power supply. However, when I send the "throttle" command to the motor, nothing happens.
The 12v power supply was measured by a multimeter to be 12.3v. The green LED on the motor hat is on.
I have verified that i2c is on. This is the output of i2c detect:
sudo i2cdetect -y 1
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:                         -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- 3c -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: 60 -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: 70 -- -- -- -- -- -- --
I also ran blinka-test with the following output:
Hello blinka!
Digital IO ok!
I2C ok!
  File "/home/hapi/hapi-water/blinka-test.py", line 16, in <module>
    spi = busio.SPI(board.SCLK, board.MOSI, board.MISO)
  File "/home/hapi/.local/share/virtualenvs/hapi-water-MyQ7nMmN/lib/python3.9/site-packages/busio.py", line 289, in __init__
    self._spi = _SPI(portId)
  File "/home/hapi/.local/share/virtualenvs/hapi-water-MyQ7nMmN/lib/python3.9/site-packages/adafruit_blinka/microcontroller/generic_linux/spi.py", line 25, in __init__
    self._spi = spi.SPI(device=(portid, 0))
  File "/home/hapi/.local/share/virtualenvs/hapi-water-MyQ7nMmN/lib/python3.9/site-packages/Adafruit_PureIO/spi.py", line 167, in __init__
    raise IOError("{} does not exist".format(device))
OSError: /dev/spidev0.0 does not exist
AFAIK SPI is not needed for this component, so I do not anticipate this being a problem, but if I am incorrect please let me know.
When I run the following test code:
# SPDX-FileCopyrightText: 2021 ladyada for Adafruit Industries
"""Simple test for using adafruit_motorkit with a DC motor"""
import time
import board
from adafruit_motorkit import MotorKit
kit = MotorKit(address=60)
print(kit)
print("Test!")
i=0
while i < 10:
    kit.motor1.throttle = 1
    time.sleep(1)
    print(i)
    kit.motor1.throttle = 0
    i += 1
print('done')
The following is output from the terminal:
<adafruit_motorkit.MotorKit object at 0x7f8b383fd0>
Test!
2
3
4
5
6
7
8
9
done
When measuring the two M1 pins on the bonnet, no voltage difference is present while this program is running.
I have tried this with 2 separate bonnets and it seems unlikely that 2 separate bonnets would both have a hardware problem, so I am assuming something about my setup is incorrect.
Any idea what next steps I should try?
Setup image attached.
2022-04-13_13-36-09 (Small).png (648.49 KiB) Viewed 120 times
adafruit_support_carter
Re: Adafruit DC & Stepper Motor Bonnet no output
If you apply the 12V directly to the motor, does it work?
Try setting throttle=1 via REPL and then measure the voltage on the output terminal screws.
billthefighter
Confirmed the motor works when connected directly to the power supply.
Motor does not work when commands sent through REPL.
REPL output:
Python 3.9.2 (default, Feb 28 2021, 17:03:44)
[GCC 10.2.1 20210110] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> exit()
After entering this command, what is the voltage on the motor output terminal block?
billthefighter
The voltage difference at the output terminal block is 0v.
Please post the electrical specs for the motor you are connecting.
billthefighter
The motor is a 12v DC motor attached to a small pump. Specifically, https://www.amazon.com/gp/product/B01G3 ... UTF8&psc=1
I have connected the iincluded power supply to the motor bonnet and am using that to drive the motor.
"12v" is not a complete electrical spec for a motor. The link also mentions "Rated current: 0.7A". But it does not specify whether that is the no-load current, stall current, maximum efficiency current etc. The included power supply is rated for 2A @12v, so I'm guessing that the 0.7A is the no-load rating.
Try changing the code to use channel 3 and test the voltage output with no motor attached.
billthefighter
See attached image - when "kit.motor3.throttle = 1" same result, 0v.
M3 voltage when kit.motor3.throttle = 1
For reference, here is the input voltage - it is now closer to 13 volts witch is a little odd. Maybe just a shitty power supply.
Input Voltage
Input Voltage
2022-04-13_17-24-17 (Small).png (566.13 KiB) Viewed 99 times
billthefighter
Ok. Problem solved. I did a reboot, and I also noticed that the motor seems to have a rectifier and can't be run backwards. I used the code here to test: https://github.com/adafruit/Adafruit_Ci ... dc_test.py
I noticed that when the "backward!" line came up on the terminal, the motor started spinning. so I swapped the pins and it began working.
I also verified that there was voltage across motor pins 1 which was not the case before.
So i think what happened was:
[*] There was some issue with I2C that was solved by a reboot
[*] The motor was installed backwards
[*] I failed to test forward and backwards operation.
Good to hear that is solved. Thanks for the follow-up.
Return to “Adafruit Raspberry Pi® accessories”
