ADS1115 Not functioning properly
- ZavierJacob
Re: ADS1115 Not functioning properly
It doesn't seem like the ads1115 is receiving the sensor values at all but channel 0 works perfectly
That is only one measurement.Sensor 1 - 2.45
sensor 2 - 2.46
with potentiometer change
What is the voltage at the minimum range of the pot?
And what is the voltage at the maximum range of the pot?
How do the actual voltages measured with the multimeter compare to the voltages reported by the code?
- ZavierJacob
When I vary the potentiometer the voltage at the sensor stays the same 2.46V but the voltage in the code ranges from 0 to 15 V for sensor 1. Sensor 2 is unaffected and displays 9 on the code regardless of the potentiometer change.
- ZavierJacob
The maximum value on the potentiometer reads a voltage of 15V on the code for Sensor 1.
OK. So it sounds like you have some sort of crosstalk between channels 0 and 1. I'm going to check with some of our python experts that are more familiar with the library you are using.
- adafruit_support_carter
You are using the ADS in a single ended setup on channels 1-3 with channel 4 not in use. Please see the example here:
https://github.com/adafruit/Adafruit_Ci ... pletest.py
and try rewriting your code to use the channel's value and voltage properties as shown, instead of calling adc.read() directly.
- ZavierJacob
This is the new code
This is the error:
# This code runs a motor clockwise and the speed is adjustable by potentiometer
import adafruit_ads1x15.ads1115 as ADS
from adafruit_ads1x15.ads1115 import Mode
from adafruit_ads1x15.analog_in import AnalogIn
import time
import smbus
import board
import busio
import RPi.GPIO as GPIO
i2c = busio.I2C(board.SCL, board.SDA)
adc = ADS.ADS1115(i2c)
#adc.mode = Mode.SINGLE
GAIN=1
chan0 = AnalogIn(adc, ADS.P0) #define channel on ads1115
chan1 = AnalogIn(adc, ADS.P1) #define channel for voltage sensor on battery1
chan2 = AnalogIn(adc, ADS.P2) #define channel for voltage sensor on battery2
chan3 = AnalogIn(adc, ADS.P3) #define channel for voltage sensor on generator
value=chan0
def setup():
global adc
if(AnalogIn(adc, ADS.P0)):
adc = ADS.ADS1115(board.I2C())
else:
print("No correct I2C address found, \n"
"Please use command 'i2cdetect -y 1' to check the I2C address. \n"
"Program Exit. \n");
exit(-1)
global p
GPIO.setmode(GPIO.BCM) #declare the GPIO settings
global value
#set up GPIO pins
GPIO.setup(17 , GPIO.OUT) # connected to pwm
GPIO.setup(22 , GPIO.OUT) # connect to In2
GPIO.setup(27 , GPIO.OUT) # connected to In1
p = GPIO.PWM(17 , 1000) # creat PWM and set Frequence to 1KHz
p.start(0)
def motor(ADC):
value = ADC
if (ADC > -16384): # turn clockwise
GPIO.output(27, GPIO.HIGH)
GPIO.output(22, GPIO.LOW)
print("Run")
p.ChangeDutyCycle(95)
elif (value < -16348):
print("Run Slow")
p.ChangeDutyCycle(75)
def parameters():
while True:
value = chan0 # read ADC from channel 0
print('ADC Value :%s' % str(value))
motor(value)
#bat1 = adc.read(1, GAIN) #read voltage sensor from channel 2
#bat2 = adc.read(2, GAIN) #read voltage sensor from channel 3
#gen1 = adc.read(3, GAIN) #read voltage sensor from generator
print('Battery 1 Voltage : %d' % ((abs(bat1)/1362)*12))
print('Battery 2 Voltage : %d' % ((abs(bat2)/1614)*12))
print('Generator Voltage : %d' % (((abs(gen1)/8192)*19)+3))
print(chan0)
print(chan1)
print(chan2)
print(chan3)
#print(bat2)
time.sleep(1)
def destroy():
p.stop() # stops PWM
GPIO.cleanup()
if __name__ == '__main__': # program entrance
print('Program is starting...')
setup()
try:
parameters()
except KeyboardInterrupt: # press ctrlc to end program
destroy()
ADC Value :<adafruit_ads1x15.analog_in.AnalogIn object at 0xb65357d0>
File "RC51.py", line 93, in <module>
parameters()
File "RC51.py", line 69, in parameters
motor(value)
File "RC51.py", line 53, in motor
TypeError: '>' not supported between instances of 'AnalogIn' and 'int'
- ZavierJacob
I fixed it. Thank you so much for all your help!!
- adafruit2
first up - your wiring is also super long and kinda messy. you should tighten everything up, make sure you have short wiring to minimize noise coupling.
also make sure your voltages don't have big resistive impedences that could make them susceptible to noise.
and REMOVE the motor, you cannot power it on the same power rails as the ADC
second, remove all the parts of the code except for reading the ADC. have two ADC reads per channel in a row to make sure you flush out any bad reads.
- ZavierJacob
Thank you, I will take all of your suggestions into consideration (especially the part about tightening up the wires). The motor is on a separate rail and powered by a different source though. After your code example, I changed the code and the sensors read fine. Now I just need to sort out why the potentiometer causes the program to quit.
