With the help of the Adafruit Pi Video Looper tutorial(https://learn.adafruit.com/raspberry-pi-video-looper) I've managed to make my Pi an incredible media player.
Also, the code has keyboard bindings included so I can stop and play the video (Thanks Adafruit!)
However, I would like to use my GPIO input instead of the keyboard binding, that way I can use a button to stop and start video playback.
So I've changed the code to the following code below.
Unfortunately, this does not seem to work.
Also, I'm not sure how to check the console messages where the print goes to, which makes it hard to do some tests/debug.
Does anyone have a clue what I'm doing wrong? I want a button to GPIO 17 to control the functionally of the key S (see def _handle_keyboard_shortcuts)
Loads of credits to the one with the solution. Thanks already
# Copyright 2015 Adafruit Industries.
# Author: Tony DiCola
# License: GNU GPLv2, see LICENSE.txt
import configparser
import importlib
import os
import re
import subprocess
import sys
import signal
import time
import pygame
import threading
from datetime import datetime
from .alsa_config import parse_hw_device
from .model import Playlist, Movie
from .playlist_builders import build_playlist_m3u
#edit
import RPi.GPIO as GPIO
# Basic video looper architecure:
# - VideoLooper class contains all the main logic for running the looper program.
# - Almost all state is configured in a .ini config file which is required for
# loading and using the VideoLooper class.
# - VideoLooper has loose coupling with file reader and video player classes that
# are used to find movie files and play videos respectively. The configuration
# defines which file reader and video player module will be loaded.
# - A file reader module needs to define at top level create_file_reader function
# that takes as a parameter a ConfigParser config object. The function should
# return an instance of a file reader class. See usb_drive.py and directory.py
# for the two provided file readers and their public interface.
# - Similarly a video player modules needs to define a top level create_player
# function that takes in configuration. See omxplayer.py and hello_video.py
# for the two provided video players and their public interface.
# - Future file readers and video players can be provided and referenced in the
# config to extend the video player use to read from different file sources
# or use different video players.
class VideoLooper:
def __init__(self, config_path):
"""Create an instance of the main video looper application class. Must
pass path to a valid video looper ini configuration file.
# Load the configuration.
self._config = configparser.ConfigParser()
if len(self._config.read(config_path)) == 0:
raise RuntimeError('Failed to find configuration file at {0}, is the application properly installed?'.format(config_path))
self._console_output = self._config.getboolean('video_looper', 'console_output')
# Load other configuration values.
self._osd = self._config.getboolean('video_looper', 'osd')
self._is_random = self._config.getboolean('video_looper', 'is_random')
self._resume_playlist = self._config.getboolean('video_looper', 'resume_playlist')
self._keyboard_control = self._config.getboolean('video_looper', 'keyboard_control')
self._copyloader = self._config.getboolean('copymode', 'copyloader')
# Get seconds for countdown from config
self._countdown_time = self._config.getint('video_looper', 'countdown_time')
# Get seconds for waittime bewteen files from config
self._wait_time = self._config.getint('video_looper', 'wait_time')
# Parse string of 3 comma separated values like "255, 255, 255" into
# list of ints for colors.
self._bgcolor = list(map(int, self._config.get('video_looper', 'bgcolor')
.translate(str.maketrans('','', ','))
.split()))
self._fgcolor = list(map(int, self._config.get('video_looper', 'fgcolor')
.split()))
# Initialize pygame and display a blank screen.
pygame.display.init()
pygame.font.init()
pygame.mouse.set_visible(False)
self._screen = pygame.display.set_mode((0,0), pygame.FULLSCREEN | pygame.NOFRAME)
self._size = (pygame.display.Info().current_w, pygame.display.Info().current_h)
self._bgimage = self._load_bgimage() #a tupple with pyimage, xpos, ypos
self._blank_screen()
# Load configured video player and file reader modules.
self._player = self._load_player()
self._reader = self._load_file_reader()
# Load ALSA hardware configuration.
self._alsa_hw_device = parse_hw_device(self._config.get('alsa', 'hw_device'))
self._alsa_hw_vol_control = self._config.get('alsa', 'hw_vol_control')
self._alsa_hw_vol_file = self._config.get('alsa', 'hw_vol_file')
# default ALSA hardware volume (volume will not be changed)
self._alsa_hw_vol = None
# Load sound volume file name value
self._sound_vol_file = self._config.get('omxplayer', 'sound_vol_file')
# default value to 0 millibels (omxplayer)
self._sound_vol = 0
# Set other static internal state.
self._extensions = '|'.join(self._player.supported_extensions())
self._small_font = pygame.font.Font(None, 50)
self._big_font = pygame.font.Font(None, 250)
self._running = True
self._playbackStopped = False
#used for not waiting the first time
self._firstStart = True
# start keyboard handler thread:
# Event handling for key press, if keyboard control is enabled
if self._keyboard_control:
self._keyboard_thread = threading.Thread(target=self._handle_keyboard_shortcuts, daemon=True)
self._keyboard_thread.start()
def _print(self, message):
"""Print message to standard output if console output is enabled."""
if self._console_output:
now = datetime.now()
print("[{}] {}".format(now, message))
def _load_player(self):
"""Load the configured video player and return an instance of it."""
module = self._config.get('video_looper', 'video_player')
return importlib.import_module('.' + module, 'Adafruit_Video_Looper').create_player(self._config, screen=self._screen, bgimage=self._bgimage)
def _load_file_reader(self):
"""Load the configured file reader and return an instance of it."""
module = self._config.get('video_looper', 'file_reader')
return importlib.import_module('.' + module, 'Adafruit_Video_Looper').create_file_reader(self._config, self._screen)
def _load_bgimage(self):
"""Load the configured background image and return an instance of it."""
image = None
image_x = 0
image_y = 0
if self._config.has_option('video_looper', 'bgimage'):
imagepath = self._config.get('video_looper', 'bgimage')
if imagepath != "" and os.path.isfile(imagepath):
self._print('Using ' + str(imagepath) + ' as a background')
image = pygame.image.load(imagepath)
screen_w, screen_h = self._size
image_w, image_h = image.get_size()
screen_aspect_ratio = screen_w / screen_h
photo_aspect_ratio = image_w / image_h
if screen_aspect_ratio < photo_aspect_ratio: # Width is binding
new_image_w = screen_w
new_image_h = int(new_image_w / photo_aspect_ratio)
image = pygame.transform.scale(image, (new_image_w, new_image_h))
image_y = (screen_h - new_image_h) // 2
elif screen_aspect_ratio > photo_aspect_ratio: # Height is binding
new_image_h = screen_h
new_image_w = int(new_image_h * photo_aspect_ratio)
image_x = (screen_w - new_image_w) // 2
else: # Images have the same aspect ratio
image = pygame.transform.scale(image, (screen_w, screen_h))
return (image, image_x, image_y)
def _is_number(self, s):
try:
float(s)
return True
except ValueError:
return False
def _build_playlist(self):
"""Try to build a playlist (object) from a playlist (file).
Falls back to an auto-generated playlist with all files.
if self._config.has_option('playlist', 'path'):
playlist_path = self._config.get('playlist', 'path')
if playlist_path != "":
if os.path.isabs(playlist_path):
if not os.path.isfile(playlist_path):
self._print('Playlist path {0} does not exist.'.format(playlist_path))
return self._build_playlist_from_all_files()
#raise RuntimeError('Playlist path {0} does not exist.'.format(playlist_path))
else:
paths = self._reader.search_paths()
if not paths:
return Playlist([])
for path in paths:
maybe_playlist_path = os.path.join(path, playlist_path)
if os.path.isfile(maybe_playlist_path):
playlist_path = maybe_playlist_path
self._print('Playlist path resolved to {0}.'.format(playlist_path))
break
else:
self._print('Playlist path {0} does not resolve to any file.'.format(playlist_path))
#raise RuntimeError('Playlist path {0} does not resolve to any file.'.format(playlist_path))
basepath, extension = os.path.splitext(playlist_path)
if extension == '.m3u' or extension == '.m3u8':
return build_playlist_m3u(playlist_path)
else:
self._print('Unrecognized playlist format {0}.'.format(extension))
#raise RuntimeError('Unrecognized playlist format {0}.'.format(extension))
else:
else:
def _build_playlist_from_all_files(self):
"""Search all the file reader paths for movie files with the provided
extensions.
# Get list of paths to search from the file reader.
# Enumerate all movie files inside those paths.
movies = []
for path in paths:
# Skip paths that don't exist or are files.
if not os.path.exists(path) or not os.path.isdir(path):
continue
for x in os.listdir(path):
# Ignore hidden files (useful when file loaded on usb key from an OSX computer
if x[0] != '.' and re.search('\.({0})$'.format(self._extensions), x, flags=re.IGNORECASE):
repeatsetting = re.search('_repeat_([0-9]*)x', x, flags=re.IGNORECASE)
if (repeatsetting is not None):
repeat = repeatsetting.group(1)
else:
repeat = 1
basename, extension = os.path.splitext(x)
movies.append(Movie('{0}/{1}'.format(path.rstrip('/'), x), basename, repeat))
# Get the ALSA hardware volume from the file in the usb key
if self._alsa_hw_vol_file:
alsa_hw_vol_file_path = '{0}/{1}'.format(path.rstrip('/'), self._alsa_hw_vol_file)
if os.path.exists(alsa_hw_vol_file_path):
with open(alsa_hw_vol_file_path, 'r') as alsa_hw_vol_file:
alsa_hw_vol_string = alsa_hw_vol_file.readline()
self._alsa_hw_vol = alsa_hw_vol_string
# Get the video volume from the file in the usb key
if self._sound_vol_file:
sound_vol_file_path = '{0}/{1}'.format(path.rstrip('/'), self._sound_vol_file)
if os.path.exists(sound_vol_file_path):
with open(sound_vol_file_path, 'r') as sound_file:
sound_vol_string = sound_file.readline()
if self._is_number(sound_vol_string):
self._sound_vol = int(float(sound_vol_string))
# Create a playlist with the sorted list of movies.
return Playlist(sorted(movies))
def _blank_screen(self):
"""Render a blank screen filled with the background color and optional the background image."""
self._screen.fill(self._bgcolor)
if self._bgimage[0] is not None:
self._screen.blit(self._bgimage[0], (self._bgimage[1], self._bgimage[2]))
pygame.display.flip()
def _render_text(self, message, font=None):
"""Draw the provided message and return as pygame surface of it rendered
with the configured foreground and background color.
# Default to small font if not provided.
if font is None:
font = self._small_font
return font.render(message, True, self._fgcolor, self._bgcolor)
def _animate_countdown(self, playlist):
"""Print text with the number of loaded movies and a quick countdown
message if the on screen display is enabled.
# Print message to console with number of media files in playlist.
message = 'Found {0} media file{1}.'.format(playlist.length(),
's' if playlist.length() >= 2 else '')
self._print(message)
# Do nothing else if the OSD is turned off.
if not self._osd:
return
# Draw message with number of movies loaded and animate countdown.
# First render text that doesn't change and get static dimensions.
label1 = self._render_text(message + ' Starting playback in:')
l1w, l1h = label1.get_size()
sw, sh = self._screen.get_size()
for i in range(self._countdown_time, 0, -1):
# Each iteration of the countdown rendering changing text.
label2 = self._render_text(str(i), self._big_font)
l2w, l2h = label2.get_size()
# Clear screen and draw text with line1 above line2 and all
# centered horizontally and vertically.
self._screen.blit(label1, (round(sw/2-l1w/2), round(sh/2-l2h/2-l1h)))
self._screen.blit(label2, (round(sw/2-l2w/2), round(sh/2-l2h/2)))
pygame.display.update()
# Pause for a second between each frame.
time.sleep(1)
def _idle_message(self):
"""Print idle message from file reader."""
# Print message to console.
message = self._reader.idle_message()
if not self._osd:
return
# Display idle message in center of screen.
label = self._render_text(message)
lw, lh = label.get_size()
self._screen.blit(label, (sw/2-lw/2, sh/2-lh/2))
# If keyboard control is enabled, display message about it
label2 = self._render_text('press ESC to quit')
self._screen.blit(label2, (sw/2-l2w/2, sh/2-l2h/2+lh))
def display_message(self,message):
if not self._osd:
return
def _prepare_to_run_playlist(self, playlist):
"""Display messages when a new playlist is loaded."""
# If there are movies to play show a countdown first (if OSD enabled),
# or if no movies are available show the idle message.
if playlist.length() > 0:
self._animate_countdown(playlist)
else:
self._idle_message()
def _set_hardware_volume(self):
if self._alsa_hw_vol != None:
msg = 'setting hardware volume (device: {}, control: {}, value: {})'
self._print(msg.format(
self._alsa_hw_device,
self._alsa_hw_vol_control,
self._alsa_hw_vol
cmd = ['amixer', '-M']
if self._alsa_hw_device != None:
cmd.extend(('-c', str(self._alsa_hw_device[0])))
cmd.extend(('set', self._alsa_hw_vol_control, '--', self._alsa_hw_vol))
subprocess.check_call(cmd)
def _handle_keyboard_shortcuts(self):
GPIO.setmode(GPIO.BCM)
GPIO.setup(17, GPIO.IN, pull_up_down=GPIO.PUD_UP)
input_state = GPIO.input(17)
while self._running:
event = pygame.event.wait()
if event.type == pygame.KEYDOWN:
# If pressed key is ESC quit program
if event.key == pygame.K_ESCAPE:
self._print("ESC was pressed. quitting...")
self.quit()
if event.key == pygame.K_k:
self._print("k was pressed. skipping...")
self._player.stop(3)
#if event.key == pygame.K_s:
if input_state == True:
if self._playbackStopped:
self._print("s was pressed. starting...")
#else:
elif input_state == False:
self._print("s was pressed. stopping...")
self._playbackStopped = True
if event.key == pygame.K_p:
self._print("p was pressed. shutting down...")
self.quit(True)
def run(self):
"""Main program loop. Will never return!"""
# Get playlist of movies to play from file reader.
playlist = self._build_playlist()
self._prepare_to_run_playlist(playlist)
self._set_hardware_volume()
movie = playlist.get_next(self._is_random, self._resume_playlist)
# Main loop to play videos in the playlist and listen for file changes.
# Load and play a new movie if nothing is playing.
if not self._player.is_playing() and not self._playbackStopped:
if movie is not None: #just to avoid errors
if movie.playcount >= movie.repeats:
movie.clear_playcount()
elif self._player.can_loop_count() and movie.playcount > 0:
movie.was_played()
if self._wait_time > 0 and not self._firstStart:
self._print('Waiting for: {0} seconds'.format(self._wait_time))
time.sleep(self._wait_time)
self._firstStart = False
#generating infotext
if self._player.can_loop_count():
infotext = '{0} time{1} (player counts loops)'.format(movie.repeats, "s" if movie.repeats>1 else "")
else:
infotext = '{0}/{1}'.format(movie.playcount, movie.repeats)
if playlist.length()==1:
infotext = '(endless loop)'
# Start playing the first available movie.
self._print('Playing movie: {0} {1}'.format(movie, infotext))
# todo: maybe clear screen to black so that background (image/color) is not visible for videos with a resolution that is < screen resolution
self._player.play(movie, loop=-1 if playlist.length()==1 else None, vol = self._sound_vol)
# Check for changes in the file search path (like USB drives added)
# and rebuild the playlist.
if self._reader.is_changed() and not self._playbackStopped:
self._print("reader changed, stopping player")
self._player.stop(3) # Up to 3 second delay waiting for old
# player to stop.
self._print("player stopped")
# Rebuild playlist and show countdown again (if OSD enabled).
#refresh background image
if self._copyloader:
# Give the CPU some time to do other tasks. low values increase "responsiveness to changes" and reduce the pause between files
# but increase CPU usage
# since keyboard commands are handled in a seperate thread this sleeptime mostly influences the pause between files
time.sleep(0.002)
def quit(self, shutdown=False):
"""Shut down the program"""
self._print("quitting Video Looper")
if self._player is not None:
self._player.stop()
pygame.quit()
if shutdown:
os.system("sudo shutdown now")
self._running = False
def signal_quit(self, signal, frame):
"""Shut down the program, meant to by called by signal handler."""
self._print("received signal to quit")
self.quit()
# Main entry point.
if __name__ == '__main__':
print('Starting Adafruit Video Looper.')
# Default config path to /boot.
config_path = '/boot/video_looper.ini'
# Override config path if provided as parameter.
if len(sys.argv) == 2:
config_path = sys.argv[1]
# Create video looper.
videolooper = VideoLooper(config_path)
# Configure signal handlers to quit on TERM or INT signal.
signal.signal(signal.SIGTERM, videolooper.signal_quit)
signal.signal(signal.SIGINT, videolooper.signal_quit)
# Run the main loop.
videolooper.run()
