If this is the wrong place to post, please let me know where I can post this. I ordered a PiOLED for this project and would hate to let it go to waste.
Hello all, I recently set up Pi Hole on my Pi zero. This is my first project so I followed all the instructions here:
https://learn.adafruit.com/pi-hole-ad-b ... 2740982-22
I reached this part and got stuck:
Create a new file with nano ~pi/stats.py and paste this code below in! Then save it.
The ~pi directory doesn't exist when I open nano. Am I missing something? Is there another
directory that I have to put the stats.py file in? Hopefully this is a noob mistake and its easily solvable. Thanks!
Beginner Needing Help Setting Up PiOLED
- bar13aro
- no_such_directory.png (521.45 KiB) Viewed 124 times
- freddyboomboom
Re: Beginner Needing Help Setting Up PiOLED
Use either '/home/pi/' or '~/' not '~pi/' for the home directory.
- adafruit_support_carter
How are you connecting to the Pi?
Looks like you are editing as user admin instead of pi?
- bar13aro
When I enter nano ~/stats.py it takes me to /home/admin/stats.py , I pasted the PiOLED code in there, is that the proper directory?freddyboomboom wrote:Use either '/home/pi/' or '~/' not '~pi/' for the home directory.
- New_Directory.png (144.82 KiB) Viewed 106 times
- bar13aro
I used putty to ssh to the Pi, and I logged in to my pi using the name and password I created when I set the Pi up. How can I edit as pi instead? Sorry I am really new to this.adafruit_support_carter wrote:How are you connecting to the Pi?
- freddyboomboom
This is basic Linux stuff.
The user you are logged in as will have a "home" directory.
The home directories are located in /home/
The learn guide presumes you are using the default user named "pi".
So for the user named "pi", the home directory would be /home/pi/
For the user named "admin", the home directory would be /home/admin/
Linux and other Unix-like operating systems have a shortcut to /home/ that is using the tilde character ~.
So with the shortcut, the home directory for the user names "pi" you could use ~/ in place of typing out /home/pi/.
You should read the Raspberry Pi Beginner's Guide from here: https://magpi.raspberrypi.com/books/beg ... ide-4th-ed There is a free PDF you can download.
Yep, agree with above. Make sure you are accessing the Pi as user pi, and not something else, like admin.
