Does anybody know the mounting dimensions of the USB C Round Panel Mount Extension Cable? The description says "The adapter is about 30mm in diameter", but is this the drill-hole size or the outer diameter? I have a 35mm hole, will this be too small or is the outer diameter large enough?
There is a drawing in the product page, but the drawing includes no dimensions other than the length. The mounting dimensions is arguably the most important dimension.
https://www.adafruit.com/product/4218
Morrious
Hole-diameter for USB C Round Panel Mount Extension Cable
- Morrious
- dastels
Re: Hole-diameter for USB C Round Panel Mount Extension Cabl
There's this https://cdn-shop.adafruit.com/product-f ... agrams.pdf for a similar part that has similar stats. Specifically, the nuts description is the same FWIW "NUT BLACK PVC 27P MOLDED". It shows a threaded section diameter of 21.7 mm.
My approach would be to get it, measure it, and cut an appropriate hole.
- dastels
I've also suggested that all the relevant x(and precise) dimensions be given for these products. Beyond that people are looking into it. Stay tuned.
- Morrious
I think it's likely these are the same diameter product for the panel-mount because I would expect the manufacturer to re-use the same design for similar products like this. 28mm is close to the "about 30mm" from the product I linked, so my guess is that's the outer dimension for all of these.
Unfortunately, I have pre-drilled holes and I was hoping this could fit. I might just go ahead and drill my own though since this seems to be the only USB-C pass-through out there other than ones designed for car BANNED-ette lighter holes.
P.S. why is "BANNED-ette" a banned word??
- Franklin97355
If the drawing is correct the diameter comes out to 27mm so I would think 28mm is OK. The flange seems to be 36mm. (using BigPrint to measure) I don't have one to measure though.
- dastels
The product page has been updated with measurements (that were done today). https://www.adafruit.com/product/4218
