I have the Stepper Motor HAT for Raspberry Pi and am having power supply issues.
Everything works great when I power the controller with my bench top power supply. However when I try to power the controller with an external wall power supply (12V 5A). Strange things happen the green power light will just flash. The stepper motor when it works just pulses. I have tried 3 different power supplies and same thing happens with all of them. When I use bench power supply and works great.
Thoughts?
Thanks!!
Stepper Motor HAT - Power Issue
Re: Stepper Motor HAT - Power Issue
What stepper motors are you using?
- cschron
STEPPERONLINE Nema 17 Stepper Motor Bipolar 2A 59Ncm(84oz.in) 48mm Body 4-lead W/ 1m Cable and Connector compatible with 3D Printer/CNC
https://www.amazon.com/Stepper-Motor-Bi ... B00PNEQI7W
Thanks!!
Thanks!!
The motor specs are incomplete, but from what is there it looks like that motor is not compatible with the HAT.
www.pololu.com carries a wide range of stepper drivers with current limiting.
Based on that, it appears to be designed for use with a current limiting 'chopper' type of driver. With a 1.1 ohm phase resistance, it will be trying to pull 10.9A per phase (21.8A total!) through the HAT - which is only rated for 1.2A per phase.Rated current 2A & resistance 1.1ohms
