I have a Raspberry Pi 4 B and a Braincraft HAT. I am following the Adafruit TensorFlow Lite 2 Setup https://learn.adafruit.com/running-tens ... te-2-setup.
In the "Install rpi-vision" section, after "pip3 install -e .", I encountered this problem -
error: subprocess-exited-with-error
x python setup.py egg_info did not run successfully.
│ exit code: 1
╰─> [12 lines of output]
Below are the Python and pip versions.
(.venv) chinpaijong@BBPi1:~/rpi-vision $ python --version
Python 3.9.2
(.venv) chinpaijong@BBPi1:~/rpi-vision $ pip --version
pip 22.0.4 from /home/chinpaijong/rpi-vision/.venv/lib/python3.9/site-packages/pip (python 3.9)
Please help.
TensorFlow Lite 2 Setup Problems
- chinpaijong
- Untitled.jpg (266.11 KiB) Viewed 245 times
- mikeysklar
Re: TensorFlow Lite 2 Setup Problems
Do yo have a development version of SDL installed? It could be an environment variable being lost due to the use of venv, but based on another forum post I’d try to just installed these packages and see it `pip install -e` works.
sudo apt-get install python-dev libsdl-image1.2-dev libsdl-mixer1.2-dev libsdl-ttf2.0-dev libsdl1.2-dev
- chinpaijong
Thank you for your quick response. Those packages seemed to have made good progress. Now this is where I got stuck.
Missing dependencies
Hunting dependencies...
SDL : found 1.2.15
FONT : found
IMAGE : found
MIXER : found
PNG : found
JPEG : found
SCRAP : found
PORTMIDI: not found
PORTTIME: not found
FREETYPE: found 23.4.17
SDL : found 1.2.15
FONT : found
IMAGE : found
MIXER : found
PNG : found
JPEG : found
SCRAP : found
PORTMIDI: not found
PORTTIME: not found
- Untitled.jpg (226.32 KiB) Viewed 230 times
- mikeysklar
Full command from this forum thread. This should help with the fonts.
https://stackoverflow.com/questions/765 ... for-pygame
$ sudo apt-get install python-dev libsdl-image1.2-dev libsdl-mixer1.2-dev libsdl-ttf2.0-dev libsdl1.2-dev libsmpeg-dev python-numpy subversion libportmidi-dev ffmpeg libswscale-dev libavformat-dev libavcodec-dev
- chinpaijong
Hi, I tried that and got "Package 'python-numpy' has no installation candidate".
Consequently, my "pip3 install -e ." still ended up with
PORTMIDI: not found
PORTTIME: not found
PORTMIDI: not found
PORTTIME: not found
- Untitled.jpg (104.59 KiB) Viewed 219 times
- mikeysklar
I can probably figure out the python-numpy and PORTMIDI/PORTTIME messages, but first we should probably back up.
Which release of Pi OS do you have installed? Has it been updated? Was it Lite or Full?
Do you see the same issues when you try to run these command not in a `venv`?
- chinpaijong
First let me say thank you. You have been very engaging in helping me solve my problems.
To answer your questions, I run version 11 bullseye (I attached a full screen shot). It has been updated almost daily. It is a full version. To be certain, I just updated it again after receiving your response, and tried to run those commands. But still got stuck on the same problem.
I run the commands outside the venv virtual environment and see the same issue.
- Untitled.jpg (94.01 KiB) Viewed 214 times
- Pi OS Version.jpg (56.12 KiB) Viewed 214 times
- mikeysklar
Your getting there. I think we need to focus on python3 package install types. Try this for numpy:
sudo apt install python3-numpy
- chinpaijong
I tried "sudo apt install python3-numpy" then come back to install the previous packages, but still got this problem "Package 'python-numpy' has no installation candidate".
- numpy.jpg (159.07 KiB) Viewed 195 times
- mikeysklar
The long string of packages to install contains python-numpy. Just change that or omit it. Here is the same list of packages, but using python3-dev and python3-numpy.
sudo apt-get install python3-dev libsdl-image1.2-dev libsdl-mixer1.2-dev libsdl-ttf2.0-dev libsdl1.2-dev libsmpeg-dev python3-numpy subversion libportmidi-dev ffmpeg libswscale-dev libavformat-dev libavcodec-dev
- chinpaijong
I have installed these packages. It would seem that I have moved beyond this step.
Next step
Next step
- chinpaijong
Next step
Next step
- Error3.jpg (62.05 KiB) Viewed 187 times
- Error2.jpg (75.29 KiB) Viewed 187 times
- Error1.jpg (144.93 KiB) Viewed 187 times
- chinpaijong
It would not let me upload doc or txt files. If you would like to see the entire terminal log please let me know. I'll just paste the whole text here.
- mikeysklar
I believe the package you want to install is python3-pygame.
Perhaps the core issue here is that you are running pip instead of pip3 along the same lines python 2.x instead of python 3.x packages.
From the Adafruit guide on TensorFlow 2 Lite Setup:
https://learn.adafruit.com/running-tens ... -3038659-2
sudo apt-get install -y libatlas-base-dev libhdf5-dev libc-ares-dev libeigen3-dev build-essential libsdl-ttf2.0-0 python3-pygame festival python3-h5py
pip3 install virtualenv Pillow numpy pygame
- chinpaijong
This did not help. I am still stuck at where I was. Same errors as before.
