TL;DR: The LCD display works, however it doesn't find the radio
I did the installs and am running the sample code from this page (also pasted below)
https://learn.adafruit.com/adafruit-rad ... y-pi-setup
When I run the script, the display lights up and the button presses show text. But the console shows this on repeat:
RFM69 Error: Failed to find RFM69 with expected version, check wiring!
Any ideas to troubleshoot?
# SPDX-FileCopyrightText: 2018 Brent Rubell for Adafruit Industries
Wiring Check, Pi Radio w/RFM69
Learn Guide: https://learn.adafruit.com/lora-and-lorawan-for-raspberry-pi
Author: Brent Rubell for Adafruit Industries
import time
import busio
from digitalio import DigitalInOut, Direction, Pull
import board
# Import the SSD1306 module.
import adafruit_ssd1306
# Import the RFM69 radio module.
import adafruit_rfm69
# Button A
btnA = DigitalInOut(board.D5)
btnA.direction = Direction.INPUT
btnA.pull = Pull.UP
# Button B
btnB = DigitalInOut(board.D6)
btnB.direction = Direction.INPUT
btnB.pull = Pull.UP
# Button C
btnC = DigitalInOut(board.D12)
btnC.direction = Direction.INPUT
btnC.pull = Pull.UP
# Create the I2C interface.
# 128x32 OLED Display
reset_pin = DigitalInOut(board.D4)
display = adafruit_ssd1306.SSD1306_I2C(128, 32, i2c, reset=reset_pin)
# Clear the display.
display.fill(0)
display.show()
width = display.width
height = display.height
# RFM69 Configuration
CS = DigitalInOut(board.CE1)
RESET = DigitalInOut(board.D25)
spi = busio.SPI(board.SCK, MOSI=board.MOSI, MISO=board.MISO)
while True:
# Draw a black filled box to clear the image.
display.fill(0)
# Attempt to set up the RFM69 Module
try:
rfm69 = adafruit_rfm69.RFM69(spi, CS, RESET, 915.0)
display.text('RFM69: Detected', 0, 0, 1)
except RuntimeError as error:
# Thrown on version mismatch
display.text('RFM69: ERROR', 0, 0, 1)
print('RFM69 Error: ', error)
# Check buttons
if not btnA.value:
# Button A Pressed
display.text('Ada', width-85, height-7, 1)
display.show()
time.sleep(0.1)
if not btnB.value:
# Button B Pressed
display.text('Fruit', width-75, height-7, 1)
display.show()
time.sleep(0.1)
if not btnC.value:
# Button C Pressed
display.text('Radio', width-65, height-7, 1)
display.show()
time.sleep(0.1)
display.show()
time.sleep(0.1)
