WebIDE not showing
WebIDE not showing
by sonite on Mon Jan 14, 2013 11:13 am
Does this work with a soft float system?
I try to connect to address: http://192.168.1.104:3000/ and nothing happens?
I tried to restart at the Rasp and no problem there. I also tried to ping with success.
sonite
Re: WebIDE not showing
by delerious on Thu Jan 17, 2013 8:07 pm
don't know about soft float, but I finally managed to get in without using the port number (3000).
http://192.168.1.60 in my case.
delerious
by sonite on Fri Jan 18, 2013 5:46 am
delerious wrote:don't know about soft float, but I finally managed to get in without using the port number (3000).
Thanks, I tried that also. It might be a problem with the soft float drives!
sonite
by der-eddy on Sat Jan 19, 2013 4:45 pm
On the setup the scripts will try to use the Port 80 (standard) for the webide
if this port is occupied the script will use the Port 3000 instead
der-eddy
by MrHermit on Sat Jan 26, 2013 2:59 pm
I was having issues as well and was able to connect by using just the IP address and not identifying the port.
J
MrHermit
