Connecting Raspberry Pi with Wifi Module
- adafruit_support_rick
Re: Connecting Raspberry Pi with Wifi Module
When you search for wifi access points on a computer, does this SSID show up in the list?
Yes. The computer I'm using now is connected to it.
Well, that was pretty much my last idea. The symptoms you're seeing are the same as I saw when I tried to connect to a router with SSID broadcast disabled. I could only connect to that router from a computer by typing in the SSID on the computer - the router would not show up in any lists of available access points (didn't want the neighbors trying to get into it…).
It turns out that I had to enable broadcast to get the Pi to connect. Apparently, it's a LInux thing - even if linux knows the SSID, it still won't connect unless SSID broadcast is enabled.
Do you have some other access point you can try attaching to? Can you switch to WPA2 encryption? Can you try turning encryption off and see if you can attach that way?
I might just try to wipe the pi and start from scratch. I can back up all the programs and other stuff I have on it...
Do you know of an easy way to do that?
You can mount the SD card as a flash drive on your computer. Or you can get another SD, flash a fresh system on it, and see if you can get that to work first.
I was also of thinking of trying to use the "network-config" package, but first I need to vnc working...
Do you think the network-config package would work? Or should I just give up and try with a new SD card?
Also, the only SD card I have laying around is an older 1GB card. Is that too small to install Raspbian?
I must plead ignorance of network-config.
1GB is too small.
1GB is too small.
I found an 8GB card, so I'll try to install fresh and see if it works.
I just tried a fresh install, and I'm still not able to connect. I've got the same symptoms as before - everything seems alright, but I can't get the RPi to connect over WLAN.
I'm out of ideas. I think your wifi dongle works, but there's something strange about your wireless network. You'll probably have better luck with this over at the Raspberry Pi forums.
OK. So, I FINALLY got it working when I found an older copy of Wheezy (from september) that worked with the RTL8188CUS setup script (instructions). Now, I'm able to ssh into my pi and ping any of the computers on my local network on it. The problem is that it seems like I'm unable to get an internet connection. When I try I get this result: . Do you know what might be causing this or how I could fix it?
@driverblock - Thanks again for all the help you've given (here and on the other thread)!
EDIT: I just rebooted my pi and now it works totally fine, without any problems at all. So, if anyone else has a similar problem, just run, and it may work itself out.
ping google.com
connect: Network is unreachable
sudo shutdown -r now
Nice work! Congrats!
So I'm back... with yet another problem.
My wifi has been working without problems since I last posted, but just tonight I've started having problems with it. It seems that every 2 or 3 minutes the wifi just drops out, and I can't ssh into the pi anymore. I can fix it by unplugging the usb hub (with wifi adapter), and plugging that in, but I need my sensors running even while I'm out of the house. I've checked my power supplies (the USB hub is 5v 1a), and I don't think that's the problem, but I just can't figure out why the wifi drops out like this.
Do you know what might be causing this?
Peter
Peter
You might want to check your hub against the naughty or nice lists.
My hub ("GearHead 4 Port Hub with Energy Saving Power Switch (5 V, 1 A)") seems to be on the nice list, but it's also crossed out in the "non-working" section.
Oddly enough, This morning I tried to plug the wifi straight into the Pi, and it's been working for about 10 hours now. Should I potentially look into buying a new USB hub? It seems like this one may be causing the problem.
