I have completed the kit and all is working.
On power off (pressing the left button), the 30 second note is displayed on the LED screen, the sound is turned down, however the RPI never shuts down. I looked a the python code and looks like the shutdown command is not working. Can someone tell me how to fix so it shuts down correctly?
Great project. Enjoyed it so far and works great!
V/R
-Michael
Raspberery Pi Internet Radio
- adafruit_support_rick
Re: Raspberery Pi Internet Radio
Did you make the following change to the PiPhy.py code, as mentioned in the tutorial?
HALT_ON_EXIT = True
Adafruit Support - Rick - Yes verified I have the code in place:
# Constants:
RGB_LCD = False # Set to 'True' if using color backlit LCD
HALT_ON_EXIT = True # Set to 'True' to shut down system when exiting
MAX_FPS = 6 if RGB_LCD else 4 # Limit screen refresh rate for legibility
VOL_MIN = -30
VOL_MAX = 5
VOL_DEFAULT = 0
HOLD_TIME = 3.0 # Time (seconds) to hold select button for shut down
PICKLEFILE = '/home/pi/.config/pianobar/state.p'
I am running Raspbian Wheezy.
The shut down error I am getting is:
PiPhi.pi line 378 in <module>
shutdown ()
File "PiPhi.py" , line 111, in shutdown
subprocess.call("sync")
NameError: global name 'subprocess' not defined
Can you tell what I need to update to fix this error for proper shut down?
Thanks again for a super product. Enjoyed adafruit for offering this kit.
V/R
-Michael
# Constants:
VOL_MIN = -30
VOL_MAX = 5
VOL_DEFAULT = 0
shutdown ()
V/R
-Michael
Try executing PiPhy.py as superuser (i.e., with "sudo")
- donde
I sure like my Raspberry Pi WiFi Radio. Just for fun I measured the power the device consumes with a Harbor Freight Power Meter. While playing wireless music I see 120 volts AC at 0.04 amps, and 3 watts. I'm using the Adafruit 5 volt, 1 amp PS. I guess running the little project 24/7 would not break the bank!
I want to thank Adafruit for sharing the coding for Pi and the LCD Pi Plate. I highly reccommend this project, but you should dedicate a Pi and LCD to the Radio if you want to keep it going.
donde
donde
Thanks for posting!
Got mine working as well and shutting down correctly. Updated the rc.local with SUDO and working great.
This is a outstanding project for anyone. Easy to build, easy to get working and then hours of enjoyment! I will look for more projects like this one!
ADAFRUIT thanks for offering this kit. I have really enjoyed building and now using WiFi audio with my RPI!
- Michael KB4JHU
- Michael KB4JHU
- donde
What did you do in rc.local? Mine shuts down, but doesn't kill power like a desktop would.Updated the rc.local
Don
