Pi 2 PiTFT Compatibility
by adafruit_support_rick on Fri Feb 20, 2015 10:59 am
Those of you with PiTFTs, you might want to check out this thread:
http://forums.adafruit.com/viewtopic.ph ... 48#p346252
Re: Pi 2 Compatibility Updates
by jbntx on Fri Feb 20, 2015 11:26 am
It does work, Rick , but as the post says, the touchscreen does not work, so it's only half a solution. I've got it running on my RPi 2, and it works quite well with a keyboard and mousepad.
jbntx
by tictag on Fri Feb 20, 2015 5:41 pm
Just spent the better part of four hours scratching my head but finally got my Adafruit PiTFT 2.2" HAT Mini Kit - 320x240 2.2" TFT - No Touch working on my RP2 :-)
I'm not a developer and words like 'kernel' scare me to death but it is possible for laypeople out there and everything you need is on notros fbtft page (https://github.com/notro/fbtft/wiki).
Installation is pretty easy but configuration of the actual screen is a bit of a pain, in short the steps are:
STEP 1: Install fbtft
sudo REPO_URI=https://github.com/notro/rpi-firmware rpi-update
STEP2: Modify config.txt by adding dtparam=spi=on and dtoverlay=pitft to /boot/config.txt
sudo nano /boot/config.txt
STEP3: Enable the screen during boot by adding fbcon=map:10 fbcon=font:VGA8x8 to the end of /boot/cmdline.txt then for a more compact font in the terminal, choose UTF8 > Guess optimal character set > Terminus > 6 x 12 (framebuffer only) using dpkg-reconfigure
sudo nano /boot/cmdline.txt
sudo dpkg-reconfigure console-setup
STEP4: Reboot to see your screen working on the RP2! :-)
sudo reboot
That's it!.......but I found that the screen was upside down (for my needs) and the overlay (read that as 'configuration') included stuff about touch screens and GPIO pins that I didn't want. In order to change the overlay (configuration) you have to download and edit an example dts file (device tree script), compile it into a dtb (device tree blob) then store it in the /boot/overlays folder, to be called during the kernel boot. YOU ONLY NEED TO DO THIS IF YOU WANT TO CHANGE THE CONFIGURATION:
STEP5: Download an example dts file, for pitft:
sudo wget https://raw.githubusercontent.com/notro/fbtft/master/dts/overlays/rpi/pitft-overlay.dts /boot/overlays/pitft-overlay.dts
STEP6: Edit it as required, for example, I changed the pitft: pitft@0 rotate parameter to 270 and completely removed the pitft_ts section. More info here: https://github.com/notro/fbtft/wiki/FBTFT-RPI-overlays
sudo nano /boot/overlays/pitft-overlay.dts
STEP7: Compile the revised dts script into a revised dtb file
wget -c https://raw.githubusercontent.com/RobertCNelson/tools/master/pkgs/dtc.sh
chmod +x dtc.sh
./dtc.sh
sudo dtc -@ -I dts -O dtb -o /boot/overlays/pitft-overlay.dtb pitft-overlay.dts
STEP8: Reboot
sudo reboot
Your revised overlay (configuration) should now be active. Sweet.
p.s. Personally I don't like booting straight in X Windows so I used the raspi-config tool to boot to the terminal only. If I want to run it, I just type xstart at the terminal.
tictag
by raskolnikoov on Fri Feb 20, 2015 8:27 pm
Hi, I have the Adafruit 2.8" TFT display with touch. Will this work for this model also (not the touch part)?
raskolnikoov
by jbntx on Fri Feb 20, 2015 8:49 pm
Yes, it will.
jbntx
Re: Pi 2 PiTFT Compatibility
by raskolnikoov on Sat Feb 21, 2015 10:47 am
I got it working today. But im having issues viewing RetroPie emulationstation on the pitft. When I start a game it goes black. Any idea?
raskolnikoov
by olipayne on Sat Feb 21, 2015 12:43 pm
raskolnikoov wrote:I got it working today. But im having issues viewing RetroPie emulationstation on the pitft. When I start a game it goes black. Any idea?
Did you up the gpu_mem?
olipayne
by raskolnikoov on Sat Feb 21, 2015 12:57 pm
Yes it's set to 256mb. I got picture on the hdmi cabel put not on pitft.
raskolnikoov
by tapanther on Sat Feb 21, 2015 2:11 pm
Hey raskolnikoov,
If I'm not mistaken, emulationstation doesn't work directly on the PiTFT. If you look at this reddit thread ( http://www.reddit.com/r/raspberry_pi/co ... _retropie/ ) you need fbcp to "copy" the image output from emulationstation to the PiTFT framebuffer, but it's a little slow.
tapanther
by antony123 on Sun Feb 22, 2015 8:01 am
my display pitft 1601 initially is white, after putting the driver turns black but do not see anything ... why?
antony123
by martywittrock on Tue Feb 24, 2015 7:12 pm
tictag,
Just a quick question - I followed all your steps and I have the display working excellent in console mode - all the characters are visible on the display and looks great..! But when I do 'startx' the PI boots directly to my HDMI screen and not to the 2.8" pitft display. I made all the adjustments to the cmdline and config files, but still not getting the Raspi to display there. I've tried the FRAMEBUFFER=/dev/fb0 startx and FRAMEBUFFER=/dev/fb1 startx commands on the console display (on the 2.8" tft at that time) and see all that happening, but it only boots to HDMI.
Any hints as to why this is happening? Please advise at your soonest - thanks..!
Marty
martywittrock
by AuronJS on Tue Feb 24, 2015 9:05 pm
Marty,
Did you modify /usr/share/X11/xorg.conf.d/99-fbturbo.conf by changing
Option "fbdev" "/dev/fb0"
to
Option "fbdev" "/dev/fb1"
AuronJS
by martywittrock on Tue Feb 24, 2015 11:16 pm
Auron,
IT WORKED..!! Many thanks for the tip on getting my 2.8" pitft to work with my Pi V2 Model B - - it looks GREAT..! :)
Thanks again -
Marty
martywittrock
by AuronJS on Tue Feb 24, 2015 11:33 pm
Awesome!!!
AuronJS
by martywittrock on Fri Feb 27, 2015 1:07 am
Auron,
Now that I have the small screen working for display (no touch), I'm not able to switch between the HDMI and the small screen like I did before by doing the following right after log-in:
FRAMEBUFFER=/dev/fb0 startx (for the small screen)
FRAMEBUFFER=/dev/fb1 startx (for the HDMI screen)
It just keeps booting into the small screen.
Is there a fix for this...? Please let me know - thanks!
Marty
martywittrock
