Raspberry Pi GPS Stratum 1 NTP Server
Tobi2707
Re: Raspberry Pi GPS Stratum 1 NTP Server
Post by Tobi2707 »
After setting the reset command still no fix or something:(
pi@raspberrypi ~ $ ntpq -pn
     remote           refid      st t when poll reach   delay   offset  jitter
 127.127.22.0    .PPS0.           1 l    -    8    0    0.000    0.000   0.000
 127.127.20.0    .GPS0.           1 l    -    8    0    0.000    0.000   0.000
Tobi2707
Post by Tobi2707 »
Any news so far?
Did you received your new Pi and the GPS HAT?:)
gtj
Post by gtj »
Tobi2707 wrote:Any news so far?
Yep, I got them both yesterday and I think I have a configuration that works. I let it run overnight and it seems to be stable so I'm going to write it up this morning.
Tobi2707
Post by Tobi2707 »
Okay that's very nice:) I Hope this will fix the problem :)
So it World be nice of you can write something like a tutorial:)
gtj
Post by gtj »
Ok, Here's the process.
  • Start with a fresh Raspian SD card.
  • In the initial configuration menu...
    • select Expand Filesystem.
    • select Advanced, SSH and enable it.
    • select Advanced, Serial, Answer No for a login shell.
    • select Finish and reboot.
  • Immediately after reboot...
    • Code: Select all
      $ sudo apt-get update
      $ sudo apt-get dist-upgrade
      $ sudo rpi-update
      $ sudo apt-get install libcap-dev libssl-dev pps-tools
    • Add dtoverlay=pps-gpio,gpiopin=4 to the end of /boot/config.txt
    • Add pps-gpio to the end of /etc/modules
    • Reboot
    • After the reboot verify that /dev/pps0 exists.
  • Build and Install NTP...
    • Code: Select all
      $ cd /usr/src
      $ sudo mkdir ntp
      $ chown pi:pi ntp
      $ cd ntp
      $ wget http://www.eecis.udel.edu/~ntp/ntp_spool/ntp4/ntp-4.2/ntp-4.2.8p1.tar.gz
      $ tar -xzf ntp-4.2.8p1.tar.gz
      $ cd ntp-4.2.8p1
      $ ./configure --enable-all-clocks --enable-parse-clocks --disable-local-libopts --enable-step-slew --without-ntpsnmpd --enable-linuxcaps --prefix=/usr
      $ make -j5
      $ sudo apt-get remove ntp
      $ sudo apt-get install ntpdate
      $ sudo make install
    • Edit /etc/ntp.conf and adjust it as follows...
      # pool.ntp.org maps to about 1000 low-stratum NTP servers.  Your server will
      # pick a different set every time it starts up.  Please consider joining the
      # pool: <http://www.pool.ntp.org/join.html>
      server 0.debian.pool.ntp.org iburst
      #server 1.debian.pool.ntp.org iburst
      #server 2.debian.pool.ntp.org iburst
      #server 3.debian.pool.ntp.org iburst
      server 127.127.20.0 mode 84 minpoll 3 iburst prefer
      fudge 127.127.20.0 stratum 1 flag1 1 flag2 0 flag3 0 flag4 0 time1 0.0 time2 0.280 refid GPS0
      # Access control configuration; see /usr/share/doc/ntp-doc/html/accopt.html for
      # details.  The web page <http://support.ntp.org/bin/view/Support/AccessRestrictions>
      # might also be helpful.
    • Delete /etc/dhcp/dhclient-exit-hooks.d/ntp to prevent dhcp from overwriting the ntp config.
    • Create the file /etc/udev/rules.d/99-gps.rules with the following contents...
      KERNEL=="pps0",SYMLINK+="gpspps0"
      KERNEL=="ttyAMA0", SYMLINK+="gps0"
    • Run sudo udevadm trigger to create symlinks /dev/gps0 and /dev/gpspps0
  • Download and Install gps-tools
    • Code: Select all
      $ cd /usr/src
      $ sudo mkdir gps-tools
      $ sudo chown pi:pi gps-tools
      $ cd gps-tools
      $ wget https://github.com/f5eng/mt3339-utils/archive/gps.zip
      $ unzip gps.zip
      $ cd mt3339-utils-gps
      $ sudo cp epoinfo epoloader eporetrieve gpsinit gpssend gpsstatus /usr/local/bin/
      $ sudo cp *.conf /etc/
  • Test GPS
    • Run sudo ppstest /dev/pps0. You should see timestamp every second. CTRL-C to exit.
    • Run gpsinit -s 115200 -f /etc/gpsinit_nav.conf /dev/ttyAMA0 to initialize the GPS unit for testing
    • Run gpsstatus /dev/ttyAMA0. Do you get a GPS or DGPS fix within 10 minutes? If not,
      Read the README at https://github.com/f5eng/mt3339-utils for instructions on how to initialize
      the GPS unit and why it's important.
  • Set up the GPS Unit for timekeeping
    • Run gpsinit -s 115200 -f /etc/gpsinit_time.conf /dev/ttyAMA0 to initialize the GPS unit
  • Start and test ntpd
    • Code: Select all
      $ sudo update-rc.d ntp defaults
      $ sudo service ntp start
      $ sudo ntpq -pn
    • If the ppstest previously passed, you should eventually see...
      oGPS_NMEA(0)     .GPS0.           1 l    1    8  377    0.000    0.001   0.004
       xx.xx.xx.xx     PPS(1)           2 u    2    8  377    0.398   -0.072   0.212
    • The 'o' in the first column indicated that ntp is using the GPS for time.
  • Notes:
    • If you're Pi isn't network connected, you can set the system clock directly from the gps using the gpsinit command as long as ntpd isn't running.
      $ gpsinit -s 115200 -i set_system_clock /dev/ttyAMA0
      To do this at startup, edit /etc/rc.local and add the following lines at the bottom before the final 'exit 0'
      service ntp stop
      /usr/local/bin/gpsinit -s 115200 -i set_system_clock /dev/ttyAMA0
      service ntp start
Tobi2707
Post by Tobi2707 »
At first thank you for your How-To:)
So i tried to follow your tutorial and i got till the point ‚Test GPS‘, but first i have some notes in my case:
gtj wrote:Ok, Here's the process.
-Add dtoverlay=pps-gpio,gpiopin=18 to the end of /boot/config.txt
-Add pps-gpio to the end of /etc/modules
Sure that it's pin 18? You also have the Ultimate GPS HAT? Shouldn't it be pin 4? With pin 4 i get the new line every second running ppstest /dev/pps0 .
gtj wrote: Build and Install NTP...
  • Code: Select all
    1 $ cd /usr/src
    2 $ mkdir ntp
    3 $ cd ntp
    4 $ wget http://www.eecis.udel.edu/~ntp/ntp_spool/ntp4/ntp-4.2/ntp-4.2.8p1.tar.gz
    5 $ tar -xzf ntp-4.2.8p1.tar.gz
    6 $ cd ntp-4.2.8p1.tar.gz
    7 $ ./configure --enable-all-clocks --enable-parse-clocks --disable-local-libopts --enable-step-slew --without-ntpsnmpd --enable-linuxcaps --prefix=/usr
    8 $ make -j5
    9 $ sudo apt-get remove ntp
    10 $ sudo make install
I'm logged in as pi so I have no permission to write in this folder. So I have to use 'sudo' in line 2, 4, 5, 7, 8 ?
And I think line 6 should be: '$ cd ntp-4.2.8p1' without the .tar.gz?
It should be said that you only use 'make -j5' if you're using a RPi 2, with and RPI B+ it's just 'make'.
So the final folder for the make command should be: /usr/src/ntp/ntp-4.2.8p1 ?
gtj wrote: [*] Edit /etc/ntp.conf and adjust it as follows...
server 0.debian.pool.ntp.org iburst noselect
Are you sure that mode 84 is right? And if so, whats the difference to 88?
gtj wrote: Run sudo udevadm trigger to create symlinks /dev/gps0 and /dev/gpspps0[/list]
Is it right that i don’t get an response output here?
gtj wrote: Test GPS
1. Run sudo ppstest /dev/pps0. You should see timestamp every second. CTRL-C to exit.
2. Run gpsinit -s 115200 -f /etc/gpsinit_nav.conf /dev/ttyAMA0 to initialize the GPS unit for testing
3. Run gpsstatus /dev/ttyAMA0. Do you get a GPS or DGPS fix within 10 minutes? If not,
Point 1 does works, but i got an error with point 2:
pi@raspberrypi ~ $ gpsinit -s 115200 -f /etc/gpsinit_nav.conf /dev/ttyAMA0
Making sure the unit is in NMEA mode
Making sure the speeds match
  File "/usr/local/bin/gpsinit", line 293, in <module>
    sys.exit(main() or 0)
  File "/usr/local/bin/gpsinit", line 263, in main
    fg = get_known_state(args.output_device, args.speed, None, False)
  File "/usr/local/bin/gpsinit", line 227, in get_known_state
    resp = send_and_wait(fg, "PMTK000", 5)
  File "/usr/local/bin/gpsinit", line 97, in send_and_wait
    thread = rx_loop_thread(fg)
TypeError: __init__() takes exactly 3 arguments (2 given)
This error als appears when im running the factory reset command, so i can't set it back to factory state.
So i can’t go on, but it is almost done:)
gtj
Post by gtj »
Tobi2707 wrote:At first thank you for your How-To:)
Yes. Pin 4 on the hat is actually wired to GPIO 18 on the Pi.
Tobi2707 wrote: I'm logged in as pi so I have no permission to write in this folder. So I have to use 'sudo' in line 2, 4, 5, 7, 8 ?
Ah, I forgot about that. Rather than doing 'sudo' for each line, you can do the following...
$ cd /usr/src
$ sudo mkdir ntp
$ sudo chown pi:pi ntp
$ cd ntp
That'll make you the owner of the directory. You'll still need to use sudo for the 'make install'.
Correct on the other points.
Tobi2707 wrote: Are you sure that mode 84 is right? And if so, whats the difference to 88?
Yes. 80 is the mode for 115200 baud. Adding 4 causes ntp to use the GPGLL sentence (the first one output). Adding 8 says to use GPZDA. Turns out GPGLL is better aligned to the PPS pulse.
Tobi2707 wrote: Is it right that i don’t get an response output here?
Correct. The links should have been created though.
Tobi2707 wrote: Point 1 does works, but i got an error with point 2:
Oops. That's a bug. I can correct that pretty quickly. Give me about 30 minutes.
gtj
Post by gtj »
Ok, I fixed the bug in gpsinit. Re-download https://github.com/f5eng/mt3339-utils/archive/gps.zip and install it and you should be good to go.
Tobi2707
Post by Tobi2707 »
Something to delete before?
And the RPi was shut down, does this matter?
gtj
Post by gtj »
Oh, you were absolutely correct on the pin being 4. I was confused. So it should be "dtoverlay=pps-gpio,gpiopin=4".
gtj
Post by gtj »
Tobi2707 wrote:Thanks:)
Nothing to delete, just recopy the files.
No issue with the Pi shutting down.
Tobi2707
Post by Tobi2707 »
Now i got this error:
The GPS speed and the port speed couldn't be synchronized.
Retrying
gtj
Post by gtj »
Just try it a few times.
Tobi2707
Post by Tobi2707 »
How often?:P
i tried it 10 times and still same error :(
Maybe something went wrong during recopy?
gtj
Post by gtj »
You're sure ntpd isn't running? Can you do the 'gpsstatus /dev/ttyAMA0'?
