White Screen on Adafruit PiTFT - 2.8" on Raspberry Pi
Re: White Screen on Adafruit PiTFT - 2.8" on Raspberry Pi
by bpb on Fri Sep 04, 2015 6:14 pm
Hey all - we just added a new 4.1 kernel to apt.adafruit.com that should include all the upstream changes and full PiTFT support. It could use a little testing before we make easy install images, if anyone wants to check it out and doesn't mind the hassle.
sudo apt-get update
sudo apt-get upgrade
...should do the trick, unless you've already pinned packages to an older version. I think you can undo that, if you have, with:
sudo apt-mark unhold sudo libraspberrypi0 libraspberrypi-dev raspberrypi-bootloader
Lemme know if there are any issues!
bpb
by adafruit2 on Mon Sep 07, 2015 2:18 pm
just to be super clear, from a fresh raspbian installation
curl -SLs https://apt.adafruit.com/add | sudo bash
sudo apt-get install adafruit-pitft-helper
sudo apt-get update
When you reboot - connect an HDMI monitor to your Pi, the top left logo should not be a raspberry pi logo - it should be an adafruit logo with a raspberry accent :)
adafruit2
Site Admin
by tomnyc on Mon Sep 07, 2015 4:23 pm
That worked for me! I have a display and wifi connectivity.
Thanks.
tomnyc
by y2kats65 on Fri Sep 11, 2015 10:12 am
I have the Adafruit 2.8" PiTFT installed on a RPI 2. I used the RPI image for this touch screen image available from your site in May. This week when I ran the "sudo apt-get upgrade" to upgrade the OS, the upgrade got stuck at the step getting the bootloader. It never went past 92%. Will this be resolved if I do the "unhold" step before upgrading? Thanks.
y2kats65
by bpb on Fri Sep 11, 2015 12:05 pm
Hi y2kats65 -
Unless you had already run
sudo apt-mark hold libraspberrypi0 libraspberrypi-dev raspberrypi-bootloader
...then the unhold step shouldn't make any difference.
It sounds like maybe your network connectivity was interrupted during the upgrade. Does this repeat every time?
bpb
by y2kats65 on Fri Sep 11, 2015 6:04 pm
Yes, I can reproduce the problem using different SD card.
y2kats65
by bpb on Fri Sep 11, 2015 6:20 pm
You might just have missed a "sudo apt-get update" somewhere in there. Otherwise, if it's not network-related (or maybe a full SD card running out of space?), this one has me a bit stumped.
We do have fresh images up, as well as new install instructions on the guide.
bpb
by adafruit2 on Fri Sep 11, 2015 6:26 pm
yah i would recommend grabbing the new images we just uploaded
adafruit2
Site Admin
cron
