Wrestling with my new Servo HAT
by GerardWassink on Wed Sep 09, 2015 12:43 pm
Hi guys,
Toay I received my Adafruit 16 channel Servo HAT. After some tinkering (hardware and software) I'm afraid that it does not work. The problem is described in this topic on the Raspberry Pi forum.
It would mean a lot to me if you guys would lend a hand, I'm at my wit's end.
Gerard
GerardWassink
Re: Wrestling with my new Servo HAT
by adafruit_support_mike on Wed Sep 09, 2015 10:55 pm
by GerardWassink on Fri Sep 11, 2015 3:08 am
Hi Mike,
Here two pictures:
Overview of setup
Closeup of servo connection
HTH, Gerard
GerardWassink
by GerardWassink on Fri Sep 11, 2015 6:11 am
Added information:
With the pigpio test program the servo works, as described on the RPi forum. Here is an image of the working signal:
Scope image while testing with pigs and pigpio, settings 50mV/cm - 5 ms /cm
So, the signal is ~ 130mV with a period of 10ms, which fits with the command: pigs s 21 1000
Pulse width varies according to the pigs setting (1000, 1500, 2000),
Next post will contain signal from the servo HAT.
GerardWassink
by GerardWassink on Fri Sep 11, 2015 7:12 am
As promised, the results of the measurements with the scope on the same settings, but now measuring the output of the servo HAT. As you can see, the timing is about right again. It seems to me the amplitude is a bit lower.
Scope image while testing with my test program, settings 50mV/cm - 5 ms /cm
GerardWassink
by GerardWassink on Fri Sep 11, 2015 7:57 am
Guys!
I'm joyed as well as flabbergasted... The servo HAT all of a sudden decided to kick in. I have NO idea what I did... Perhaps it got frightened by all you guys help. Anyway, the code below gave me a nice result now.
See also this Youtube movie.
#!/usr/bin/python
from Adafruit_PWM_Servo_Driver import PWM
import time
# *** Test Code
# Initialise the PWM device using the default address
pwm = PWM(0x40)
# I Want debug output
#pwm = PWM(0x40, debug=True)
servoMin = 210  # Min pulse length out of 4096 (~ 10ms)
servoMax = 400  # Max pulse length out of 4096 (~ 20ms)
speed = 0.01
pwm.setPWMFreq(50)                      # Set frequency to 50 Hz
while (True):                     # Change angle of servo
  for i in range(servoMin, servoMax):
    pwm.setPWM(0, 0, i)
    time.sleep(speed)
  for i in range(servoMax, servoMin, -1):
    pwm.setPWM(0, 0, i)
    time.sleep(speed)
GerardWassink
