Problem with Software PiPhone.py
Gonca27
Post by Gonca27 »
Good evening. I chose one of the projects published in Adafruit's page named Piphone as my ''PAP'' project in school. Im getting a problem and i can't currently solve it. I followed all of your indications, step-by-step, as showed in this page: https://learn.adafruit.com/piphone-a-ra ... e/pi-setup
When i try to run the software Pihpone.py, the screen rotates horizontally, fully disabling me of seeing the software at all. How can i rotate the screen vertically in order to use this software?
adafruit_support_mike
Re: Problem with Software PiPhone.py
Post the contents of /etc/modprobe.d/adafruit.conf and we'll make sure the rotation is set correctly.
Gonca27
Post by Gonca27 »
At "etc/modprobe.d/adafruit.conf" i typed: "options fbtft_device name=adafruitct28 rotate=0 frequency=32000000"
Double-check the contents of the file to make sure it's character-for-character identical to the text in the tutorial. It's one of those places where it's easy to make a typo, and every letter matters.
Gonca27
Post by Gonca27 »
I opened the adafruit.conf file with LibreOffice Writer and found that the code was exactly the same as it asks the tutorial.
Gonca27
Post by Gonca27 »
I need to solve this problem fast. I'm almost out of time to finish this project.
Try changing the value of 'rotate' to 1, 2, or 3 and see what effect that has.
Gonca27
Post by Gonca27 »
I tried to change the value to 1,2 and 3 and nothing has changed. It stood the same as the image i posted here.
That suggests a problem in the config file. Config file parsers usually stop reading when they hit an input character they don't expect. Please post the contents of the file.. not what you think you typed, but a byte-for-byte copy of the file.
Gonca27
Post by Gonca27 »
In the folder "adafruit.conf", i have : ''options fbtft_device name=adafruitct28 rotate=0 frequency=32000000''. Im leaving here some photos i captured to confirm.
adafruit2
Post by adafruit2 »
the rotate value should be 90, 180 or 270 not '0, 1, 2, 3'- try those!
