Raspberry Pi - Stop to work
by rodrigokroll on Mon Mar 28, 2016 2:15 pm
My Raspberry Pi 2 - Model B - ARMv7 with 1G RAM[ID:2358] stopped to work after I rebooted the system right after a linux "dd" command from a local ISO file to one of the USB devices (/dev/sda1).
The SD card I tested in another machine and is working, I formatted and recreate the partitions also but still not working.
Both LED's (red and green) stay ON when I plug the power.
Eveything was working fine with Raspbian, after the "dd" command and then the reboot command, Raspberry never came back.
I'd like to know if is there any additional procedure to be done or a reset factory of the board or just the replacement.
Full name: Rodrigo Kroll Palhares
Order Confirmation No: 904685-1169476070
Looking forward to your contact,
rodrigokroll
Re: Raspberry Pi - Stop to work
by adafruit_support_bill on Wed Mar 30, 2016 10:03 am
[moved to the Raspberry Pi forum]
Did you test with another Raspberry Pi and verify that it boots?
by rodrigokroll on Wed Mar 30, 2016 10:14 am
No, unfortunately I don't have another Raspberry to test.
I tested using the SD card in another machine and the SD card is recognized correctly. Also, I changed delete the partition and create as NTFS and was possible to read/write files to the SD Card.
I appreciate your contact,
rodrigokroll
by adafruit_support_bill on Wed Mar 30, 2016 10:52 am
I suspect that your 'dd' command may have inadvertently overwritten the boot partition on the card. Let me check with one of our experts in that area.
by rodrigokroll on Wed Mar 30, 2016 11:06 am
I totally understand your point, but after the system crashes I erased the SD card and prepared it again to boot. As far as I know the dd could corrupt the SD card data through a buffer overflow, but don't damage the SD card hardware. That's why I recreated the SD card with the appropriately image in order to try loading the system again.
rodrigokroll
by adafruit2 on Wed Mar 30, 2016 11:27 am
its *possible* but unlikely - i'd use the raspberry pi loader on windows or mac and try that - the Pi is probably fine. you may need a new SD card
if it worked and you did something and it stopped working after that thing, its probably the thing that did it ;)
adafruit2
Site Admin
by rodrigokroll on Wed Apr 06, 2016 11:24 pm
Hello guys.
I just tested with a new SD card and I faced with the same behavior.
Unfortunately, is not working.
rodrigokroll
by adafruit_support_bill on Mon Apr 18, 2016 9:52 am
When did you purchase the Raspberry Pi?
by rodrigokroll on Mon Apr 18, 2016 10:40 am
On 10/21/15.
rodrigokroll
by adafruit_support_bill on Mon Apr 18, 2016 10:44 am
Our warranty return/replace policy on these is 30 days.
