I just purchased a RPI3 from you guys and while I have installed Raspbian using Noobs, I can't run sudo apt-get update or sudo apt-get install.
I keep getting the following error:
E: the method driver /usr/lib/apt/methods/https could not be found
N: Is the package apt-transport-https installed
If I try to find /etc/apt/sources.list, there is no directory called apt in the 'etc' folder
