Hi, I'm just wondering if the Bluefruit EZ-link is compatible at all with the Flora. The method shown in this guide https://learn.adafruit.com/introducing- ... rogramming will "not work with the Flora," but I'm wondering if there's just another way to do it then.
And yes, I am aware of the module designed specifically for the Flora, but the EZ-link is the bluetooth module I have currently.
-Elliot
Bluefruit EZ-link compatible with Flora?
Re: Bluefruit EZ-link compatible with Flora?
You can't program a Flora through an EZ-Link, but you can communicate with one.
The Uno uses an ATmega328 microcontroller, which can't handle USB signals by itself. It has to rely on an external USB-to-Serial converter, and the bootloader gets its data from a Serial connection on pins 0 and 1. The EZ-Link can hijack that connection and provide an alternate source for the Serial data on pins 0 and 1.
The Flora uses an Atmega32u4, which can handle USB signals internally, so the Flora's bootloader can get its data directly from the USB jack. There's no USB-to-Serial conversion step that the EZ-Link can hijack.
Once you have code running on the Flora, it can communicate through an EZ-Link connected to its hardware Serial port, but that's different from programming.
