Neopixel Sound Reactive Peace Pendent
by jennytorino on Sun May 13, 2018 10:46 pm
I built the neopixel sound reactive pendent in the tutorial using the 12 Neopixel ring and Gemma M0. I loaded the code onto the Gemma using Circuit Python and the ring does react to sound, but when it is silent it never shuts completely off. At the most the lights only go off halfway around the ring. Is there something I need to adjust with the code to fix this?
Also, when recharging the lipoly battery using the miniusb recharger the charger light never goes from red to blue indicating a charged battery. It gives a red light when charging and then eventually the light shuts off. Any ideas as to why this could be happening?
Thanks in advance for your help.
Jenny
jennytorino
Re: Neopixel Sound Reactive Peace Pendent
by adafruit_support_carter on Tue May 15, 2018 11:51 am
It sounds like you're having an issue on both ends. They don't all turn off when silent. And the most you can get to light up is only half of the pixels. How many are on when silent?
It's suppose to go green when charging is complete:
https://learn.adafruit.com/adafruit-mic ... tator-leds
But the red light turning off is also an indication that charging is complete. Does it seem like the battery is at least charging?
It might help to see your build. Can you post a photo showing how everything is connected.
by jennytorino on Tue May 15, 2018 6:15 pm
I can get the LEDS to light up around the entire ring with loud sounds, but in silence only half the LEDS will turn off. Half the the ring will stay lit in silence.
The battery light will be red when charging and then shuts off (instead of giving a green light). It does charge though because it ran out of power, I charged it, and it worked.
jennytorino
by adafruit_support_carter on Thu May 17, 2018 12:01 pm
I've passed this on to the guide author. It may be something with the current version of the code.
by adafruit2 on Thu May 17, 2018 1:00 pm
oops can you try this code? let me know if that works :)
https://github.com/craigargh/Adafruit_L ... Pendant.py
adafruit2
Site Admin
by jennytorino on Sun May 20, 2018 11:07 pm
Yes, this works! Thanks!
jennytorino
