Gemma > No Red LED Pulse
by WILLPOWERSTUDIOS on Tue Feb 27, 2018 10:17 pm
Photo of the gemma with the red light never blinking
Arduino > error message + board
I’m attempting to upload this blink code (https://learn.adafruit.com/introducing- ... rduino-ide) but the gemma is not blinking red.
I selected board > Adafruit Gemma (ATtiny85 @ 8Mhz)
I hit the reset button as mentioned on page > https://learn.adafruit.com/introducing- ... rduino-ide
Here is the Error Message from Arduino:
Arduino: 1.8.5 (Mac OS X), Board: "Adafruit Gemma (ATtiny85 @ 8MHz)"
Sketch uses 680 bytes (12%) of program storage space. Maximum is 5310 bytes.
Global variables use 9 bytes of dynamic memory.
avrdude: Error: Could not find USBtiny device (0x1781/0xc9f)
I tried both USB ports of my MacBook Pro.
Thank you for your help.
Product: https://www.adafruit.com/product/1222
This is what I am following: https://learn.adafruit.com/introducing-gemma
Link to project I am attempting to make: https://learn.adafruit.com/gemma-powere ... s?view=all
WILLPOWERSTUDIOS
Re: Gemma > No Red LED Pulse
by fid on Fri Sep 07, 2018 10:24 pm
Sorry that you didn't get a reply. I am using a MacBook Pro and cannot upload any code to a Gemma. It is an older Gemma, not the MO. I have tried both USB ports on the Mac and two different good cables. I think that the fix is you will need a powered USB hub. I was successful uploading Arduino code to a Gemma with my MacBook Pro previously. I lost my powered USB hub due to a fire and have ordered a new one. It should be here within the hour. (Most likely it will be tomorrow.) I can return here and report my success or failure.
-> Greg
fid
by WILLPOWERSTUDIOS on Sun Sep 09, 2018 9:47 am
Hi Fid,
Thank you so much for your reply. Ok, so an USB Hub...
Sure, I would love to get your answer after your test !
Thank you !!
WILLPOWERSTUDIOS
by adafruit_support_carter on Tue Sep 11, 2018 12:53 pm
Definitely make sure you are using a good USB cable that is NOT charge only. Are the USB ports you are trying to use all USB 3.0?
by WILLPOWERSTUDIOS on Fri Sep 14, 2018 5:24 am
Hi, I was using USB 3.0.
As far as the USB Cable, it was thick so I presume that it did more then charge, but perhaps I should try again with another one.
Thank you for helping me.
WILLPOWERSTUDIOS
