I messed up my Gemma M0 somehow.
by agilliam on Wed Oct 10, 2018 5:47 pm
Hey all, I have received my Gemma M0 and when I plugged it in it was flashing through the RGB test code like normal. I thin assembled my two new your pixie sticks for the unicorn horn for my daughter’s Halloween costume. I uploaded the sample code and everything worked fine it was fading through the colors like it should. However I wanted to change the rate and it was changing and when I did that somehow a corrupted the main.py file. Now I can’t get it to do anything I can’t even save the main.py from the original test code back to the drive.
I have uploaded the uf2 firmware/image to my drive f:\ using boot loader mode. But still nothing. Now my led bro pixels don’t even light up! What did I do and how do I fix it?
agilliam
Re: I messed up my Gemma M0 somehow.
by agilliam on Wed Oct 10, 2018 5:53 pm
Sorry for the typos. Siri is making me mad. It keeps messing up my posts.
I’m using the 8 led NEO pixel sticks.
agilliam
by agilliam on Wed Oct 10, 2018 9:26 pm
As an update and desperate attempt to fix this, I tried deleting all files on the drive and extracting the zip file from the adafruit website. It is now back the way it was when I received it. With 1 major problem. It still isn’t working. Not the default python code or the unicorn python code. And I have renamed the files to main.py.
Nothing is working at all. I’ve double, triple and quadruple checked the connections. Only 3 wires and they are wired correctly. I have green as ground going to GND on Gemma to the GND pad on NEO pixels. I have purple wire going from D1 on Gemma to the DIN pad on the NEO Pixels. And red connected to VOUT to the 5VIN pad.
I have used double sided tape to stick them together and insulate the pads and solder joints. Using 4 pin smd style XH connectors.
Here are a few pics.
agilliam
by agilliam on Wed Oct 10, 2018 9:44 pm
Never mind. It’s been fixed. Took a lot of research but is good now.
agilliam
by agilliam on Wed Oct 10, 2018 10:14 pm
It only works when I program it using Arduino IDE. As soon as I put circuitpython / circuitplayground, it does nothing.
Anyone help me with that?
agilliam
by danhalbert on Sun Oct 14, 2018 9:13 am
How did you fix it?
How are you reloading CircuitPython, what version, did you add libraries, and what's in main.py or code.py?
danhalbert
by agilliam on Wed Oct 24, 2018 11:58 am
The fix was using Arduino IDE to program it. However I can’t get circuit playground to work. I have downloaded the files from your page link and downloaded for Gemma M0. I pressed reset 2x and put it into flash mode and drag and dropped the image over to the appropriate drive. It comes back after flashing but main.py is blank. I didn’t check code.py. It’s been almost 2 weeks now so I gave up on that one. I’ll check and get back. I’d really like to get it working correctly.
agilliam
by danhalbert on Wed Oct 24, 2018 12:47 pm
The Gemma is not a Circuit Playground? Which file did you download to load CircuitPython on it, and how did you try to load CircuitPython?
You want to download: https://github.com/adafruit/circuitpyth ... -3.0.3.uf2
then double-click the reset button to get GEMMABOOT, and drag the .uf2 above to GEMMABOOT.
Also, I happen to have made up a fresh load for Gemma M0 with libraries and the demo program. See this page:
https://learn.adafruit.com/adafruit-gemma-m0/downloads
Download this: https://cdn-learn.adafruit.com/assets/a ... 1539974383 (Update to CircuitPython 3.0.3 with lib and demo main.py file: gemma-m0-circuitpython-main-lib-3.0.3.uf2)
danhalbert
