Wearable as a controller ?
by quanten on Wed Jul 03, 2019 7:59 am
Hello experts,
I am new to Wearables and want to add wearable control to my arduino project (which is currently a smartphone/bluetooth controlled toy car).
Is it possible to replace smartphone by a wearable device in this case ? If yes can someone help me understand what all do I need ?
Going through all the available products/boards/posts I am a little confused as to what all do I need to get my project running.
So my questions are :
1. Do I need Flora and/or Bluefruit ?
2. How do I add different sensors like accelerator and gyroscope to the wearable unit above ?
3. To make it truely wireless wearable, Please also suggest a battery (and a charger ) that I should I use.
Thanks.
quanten
Re: Wearable as a controller ?
by adafruit_support_bill on Wed Jul 10, 2019 10:30 am
What type of bluetooth communication are you currently using? We do have Feather processors that are capable of acting as a central bluetooth device for Bluetooth BLE.
https://learn.adafruit.com/bluefruit-nr ... entral-hrm
by quanten on Wed Jul 10, 2019 10:38 am
Thanks. I am currently using hc-06 for bluetooth communication between arduino and my android phone.
@ 'Feather processors that are capable of acting as a central bluetooth device for Bluetooth BLE'
So this will be part of the werable unit and can be used as a bluetooth transmitter ?
Also, how would sensors (accelrometer etc.) sensor fit in this set up ?
quanten
by adafruit_support_bill on Wed Jul 10, 2019 11:07 am
The HC-06 is not a BLE compatible device. So you may need to make changes to your robot hardware as well.
The Feather processor boards are compact, so they are well suited for wearable applications - as well as robots. To keep wiring simple, I would recommend selecting accelerometers and other sensors with i2c interfaces where possible. The NRF52 Feather has both i2c and SPI device buses.
by quanten on Wed Jul 10, 2019 8:16 pm
Thanks. Can you suggest a bluetooth device that is arduino and BLE compatible and a accelerometer with I2C interface ?
So if I understand it right ,
- Feather processor boards that will connect to the accelerometer (and other sensors) will be the wearable unit
- The wearable unit above will talk to the arduino on the robot through a bluetooth device that will be BLE compatible.
PLEASE confirm if my understanding is right.
quanten
by adafruit_support_bill on Wed Jul 10, 2019 8:24 pm
There are many i2c accelerometers to choose from. The LSM303 combines accelerometer, magnetometer and gyro functions into one compact package:
https://www.adafruit.com/product/1247
I will check with some of our Bluetooth experts for recommendations on BLE processor choices.
by quanten on Wed Jul 10, 2019 8:43 pm
Thank you. Yews please let me know.
And is the set up going to look like what I have described ?
quanten
by adafruit_support_bill on Thu Jul 11, 2019 5:44 am
Yes. You will need to set up the Feather in your controller as a Bluetooth BLE Central device. Then you will need another BLE device in your Robot set up as a BLE Peripheral that can pair with the controller.
by adafruit_support_bill on Thu Jul 11, 2019 9:22 am
I spoke with some of our Bluetooth experts. This was their recommendation:
Since Central mode is a requirement,
nRF52832 or nRF52840 Feathers are the choice. '840 is much more capable,
and can run CircuitPython (including, soon, Central mode),
by quanten on Thu Jul 11, 2019 12:55 pm
Thanks for your help.
Since you mentioned hc-06 is not BLE compatible, can you suggest a good bluetooth module for this project ( that is BLE compatible) ?
Since I need nRF52840 Feather to be used in central mode, do you know What are my options other than circuitpython for programming nRF52840 ?
Also, is nRF52840 currently out of stock ?
quanten
by adafruit_support_bill on Thu Jul 11, 2019 1:12 pm
Since I need nRF52840 Feather to be used in central mode . . .
You only need the 52840 if you want to use CircuitPython. For Arduino programming, you can use the nRF52832.
You can use another nRF52832 or nRF52840 Feather on the robot side as the BLE peripheral.
These can be programmed using the Arduino IDE also as shown in the guide:
https://learn.adafruit.com/bluefruit-nr ... al-bleuart
If you register for notifications, you will get an email as soon as they are back in stock.
