Adafruit Industries, Essential service and business: NYC – Executive Order 202.6 - Read more.
Lightsaber
Lightsaber
by Raffistyle on Wed Mar 25, 2020 6:38 am
Ok, I purchased a new M4 Express and a new prop-maker. Followed the Ruiz brothers- tutorial exactly, used the latest CircuitPy and the matching libraries, and still get the pulsing yellow light. After doing some google searching, I found I'm not the only one with this problem. Maybe I haven't looked in the right place but other than the Ruiz Brothers, I don't know of any other builders in the "lightsaber community" using Adafruit boards. Which makes me wonder.
Raffistyle
Re: Lightsaber
by dastels on Wed Mar 25, 2020 10:18 am
Safe mode. I've found that's often power related. The lightsaber has a lot of NeoPixels in it. A couple questions: what color were you setting the blade to, and what brightness are they set to?
dastels
Re: Lightsaber
by Raffistyle on Wed Mar 25, 2020 12:53 pm
I believe the code is written to display purple at full brightness
Raffistyle
Re: Lightsaber
by dastels on Wed Mar 25, 2020 1:20 pm
Try reducing the brightness and/or using just red, green, or blue. If that works, then it's the case of the NeoPixels drawing too much current. At full brightness purple - purple uses both red and blue - each NeoPixel will draw 40mA. Using just red, green, or blue will only draw 20mA per NeoPixel. Reducing brightness will reduce the current draw as well.
When too much current is drawn, the battery voltage can dip and the board experiences what is essentially a brown-out which, if serious enough, will crash it and put it into safe mode.
dastels
Re: Lightsaber
by Raffistyle on Wed Mar 25, 2020 1:39 pm
Thanks Dave. I will give that a shot.
Raffistyle
Re: Lightsaber
by Raffistyle on Thu Mar 26, 2020 5:33 pm
Nope same problem. I wonder if this problem was ever solvrd.
https://www.reddit.com/r/adafruit/comme ... ork_right/
Raffistyle
Re: Lightsaber
by dastels on Thu Mar 26, 2020 6:01 pm
Try this: change the number of pixels to 5. See if that helps.
You're using this guide, right? https://learn.adafruit.com/lightsaber-featherwing
dastels
Re: Lightsaber
by Raffistyle on Thu Mar 26, 2020 6:39 pm
Yes, but only using 60 pixels on my strip
Raffistyle
Re: Lightsaber
by Raffistyle on Fri Mar 27, 2020 2:32 am
No change. With the Prop-maker it goes into safe mode, When I run the M4 in MU's REPL, I get
code.py output:
File "code.py", line 53, in <module>
RuntimeError: SDA or SCL needs a pull up
The same problem I had with the first M4 and Prop-maker I purchased. The only difference was the first one, I used just a momentary push button with out the RGB part in the code. I started over thinking I may have messed up in my soldering or something,
Raffistyle
Re: Lightsaber
by dastels on Fri Mar 27, 2020 9:08 am
Possibly. Double check all your soldering. Post a clear photo of the soldering if you'd like feedback.
dastels
