Ring not programmable
by Kadeca on Wed Jul 29, 2020 8:40 pm
I received RFID / NFC Smart Ring and received today. I put in notes that the ring needed to be programmable IC Type A 13.56. I have scanned ring on every frequency and it does not show up. It consistently says read failure. It also has no engravings leading me to believe it is a fake that someone returned. It was opened and had no instructions. I looked all through your website and tried all troubleshooting methods. Ring does not work. I have programmed multiple other RFID tags.
I need to return and get a replacement sent immediately.
Kadeca
Re: Ring not programmable
by adafruit_support_carter on Thu Jul 30, 2020 1:36 pm
Can you provide more details about the hardware you are using to try and read from the RFID ring?
by Kadeca on Thu Jul 30, 2020 2:16 pm
Using the same one that is shown on the instructions. And I’ve used it on many other HiD and IC cards, tags, tokens. Programmer Works fine. The problem is the ring.
Kadeca
by adafruit_support_carter on Thu Jul 30, 2020 2:22 pm
OK, that's the one we know it *should* work with. So let's work with that. Just to be sure, you're following this Learn guide?
https://learn.adafruit.com/nfc-ring-password-helper
by Kadeca on Thu Jul 30, 2020 2:44 pm
Yes I followed the guide perfectly, again I have programmed many other tags. The ring is not even scannable more readable On any frequency and on any frequency and It is not working.
Kadeca
by adafruit_support_carter on Thu Jul 30, 2020 3:10 pm
That guide has an example that shows how to use the ring with a keyboard emulator to enter a password. But prior to that, it links to this more general guide here:
https://learn.adafruit.com/adafruit-pn532-rfid-nfc
That guide has a more basic functional check example. Were you using that for testing?
https://learn.adafruit.com/adafruit-pn5 ... no-library
If so, what did you get in the Serial Monitor when you ran it?
by Kadeca on Thu Jul 30, 2020 4:08 pm
I don’t understand why this is so confusing. It’s not reading anything at all. Not readable. No frequency at all under any frequency.
Kadeca
by adafruit_support_carter on Thu Jul 30, 2020 4:45 pm
Is that based on using the hardware and examples per the guide? Or with your hardware?
If you ran the example from the guide, what did you get in the Serial Monitor?
by Kadeca on Thu Jul 30, 2020 9:13 pm
What other hardware would I use other than my own hardware that I already uploaded a picture of?
Kadeca
by Kadeca on Thu Jul 30, 2020 9:17 pm
I don’t have this hardware and I’m not trying to install the password helper. The guide doesn’t not show anything about programming using the reader/writer that I already posted a picture of.
Kadeca
by Kadeca on Thu Jul 30, 2020 9:18 pm
I don’t have this hardware - Adafruit PN532 RFID/NFC Breakout and Shield, and I’m not buy more hardware. This rfid ring should be programmable with the hardware I have.
Kadeca
by adafruit2 on Fri Jul 31, 2020 7:01 pm
well, for one, the scanner says 125KHz.
do you know for a fact it supports ntag2x3 13 MHz?
then, have you tried a smartphone? most have RFID ntag support in them and have free apps
please email support@adafruit for a refund
adafruit2
Site Admin
