Gemma M0 shows no sign of life after arrival
by D4EE on Sun Jul 18, 2021 4:00 pm
Hello!
I ordered a Gemma M0 from the Adafruit Shop directly and it arrived quickly, but it seems to be defect.
I tried to connect it to a PC via a USB-Cable that I know can transmit data, but no LED turns on at all, nor does it connect to the PC. I tried switching it on and off multiple times, as well as double-clicking the Reset Button a lot, but it doesn't show any signs of life.
Are there any things that I can try out? I have a multimeter lying around to test stuff.
Otherwise, is there a way to refund/resend this item?
Best Regards
D4EE
Re: Gemma M0 shows no sign of life after arrival
by dastels on Sun Jul 18, 2021 4:45 pm
Do you want to use it with C++ (often called Arduino in this context) or CircuitPython?
As background, have you read the product guide: https://learn.adafruit.com/adafruit-gemma-m0?
dastels
by D4EE on Mon Jul 19, 2021 9:33 am
Hi Dave,
I'd like to use this board with Cicruit Python, but C++ would also be okay.
My main concern is getting this board to work at all. I read the product guide and tried to set up the connection to the PC as described in there, but nothing really happens (Meaning my computer doesn't recognize any USB device when plugging it in, nor do any of the LEDs light up on the board.
I tried installing the drivers and testing it on two different PCs with a lot of different cables, but nothing worked yet.
D4EE
by dastels on Mon Jul 19, 2021 10:32 am
OK. Let's do a quick check that the board is getting power. Plug it into USB and check the voltages at the Vout and 3v pads.
dastels
by D4EE on Mon Jul 26, 2021 12:00 pm
Hey Dave,
sorry for the late answer, I somehow must have overlooked the mail that I got an reply.
I measured the voltage at Vout (Measured: 5V) and 3V (Measured 3,3V). So the board seems to be getting power.
D4EE
by dastels on Mon Jul 26, 2021 12:17 pm
OK, the power circuit is working (and you have the switch "on") so the only other thing is the processor which seems to be DOA.
Please email support@adafruit.com with a link to this thread, your order number, and request the replacement of one Gemma M0.
dastels
