Hello -
I'm following the instructions for the Bionic Eye project and am a little confused when I get to the CircuitPython Code page:
https://learn.adafruit.com/3d-printed-b ... ython-code
Where I am lost is the instructions in the code say, "Required library is the Adafruit_SoftServo library available at https://github.com/adafruit/Adafruit_SoftServo" and there is code at the bottom of the page that I'm not sure what to do with:
$ mkdir /Volumes/CIRCUITPY/lib
$ cp -pr adafruit_motor /Volumes/CIRCUITPY/lib
Do I add the Adafruit_SoftServo library to my CIRCUITPY drive? It seems like an IDE code. What do I do with that bit of code at the bottom of the page?
Thanks for your help
Bionic Eye CircuitPython Code
- mikeysklar
Re: Bionic Eye CircuitPython Code
I think I already replied to this one. The Adafruit_SoftServo library is Arduino only and not at all applicable. You have followed the instructions correctly if you pasted the example code into code.py and copied the entire adadfruit_motor folder into the /Volumes/CIRCUITPY/lib folder.
- bguenther
Yes, thank you! Sorry for the re-post.
I've uploaded everything correctly, but the project still isn't working. I suspect that it might be the battery pack since nothing is lighting up when it is unplugged from the computer, but shouldn't it work when connected via USB?
- mikeysklar
Let's get into the specifics of your setup.
Are you using a Trinket M0?
When you plug it into your computer do you see the drive mounted? What files are listed?
- bguenther
Yes, I have a Trinket M0 and the CIRCUITPY drive pops up when I plug it in. I was able to get the Blink sketch to run fine on it. I'm providing a screenshot of the files listed.
I'm not sure if these means anything, but the Trinket lights up when I move the servo arms by hand.
Thanks again for your help with this.
- Attachments
- Image 10-22-21 at 1.02 PM.jpg (68.59 KiB) Viewed 524 times
- mikeysklar
Thank you for the CIRCUITPY screenshot. This look good and I'm glad you got the Trinket successfully running blink.
Let's make sure your bootloader, CircuitPython and libraries are up to date.
You can double tap reset and check out the TRINKETBOOT drive (or something *BOOT). There will be a file INFO_UF2.txt which has the bootloader version you are on. It should be v3.13.0.
Make sure you are running CP 7.x with the current version 7.x bundle for adafruit_motor.
https://circuitpython.org/board/trinket_m0/
https://circuitpython.org/libraries
After we confirm you are current we can get back into making the steppers go.
- bguenther
Okay! My boot loader was out of date and is now updated. I also installed the latest adafruit_motor files.
- mikeysklar
Alright. Congrats on the bootloader and library files.
Can you also confirm that you are running CircuitPython 7?
Are you still seeing errors? If so what is on the REPL console?
- bguenther
I am running Circuit Python 7.
When I save the code, the console says:
Code stopped by auto-reload.
soft reboot
Auto-reload is on. Simply save files over USB to run them or enter REPL to disable.
code.py output:
soft reboot
code.py output:
- mikeysklar
@bguenther,
This all sounds good. The console seems to be showing when you save the code that is reloading the controller with it and the code is running without error.
Can you paste in the code you are running and a photo of your wiring? It does not seem like you have a software issue, but maybe a connectivity problem?
- bguenther
Since we pretty much ruled out software being a problem, I swapped out the battery pack with another I knew worked and that did the trick. The Trinket lit up and the servos started moving. Thanks again for your help walking me through all this.
- mikeysklar
Good working figuring out that this was a power issue. Congrats.
