Gemma M0 + Flora Bluefruit
by siz3thr33 on Tue Nov 30, 2021 9:33 pm
Hey Adafruit! I am hoping to add some bluetooth to a project I'm working on where the main board is the Gemma M0. It seemed to me like the board was almost identical to the Flora, so I took a leap of faith and picked up some of the flora bluefruit le modules hoping the Gemma would work more or less the same as the Flora.
For the wiring (power and ground excluded from the diagram, I'm assuming I figured that out correctly), I have the "A1" pin(?) on the Gemma hooked up to the "TX" pin(?) on the Bluefruit, and the "A2" pin(?) on the Gemma hooked up to the "RX" pin on the Bluefruit:
   |    |       | USB IN |      |   |
   |    |         GEMMA         |   |
   +----| | A1/D2 |  | GRND  |  |   |
   +----| | A2/D0 |  | D1/A0 |  |   |
   |    | | 3Vo   |  | VOUT  |  |   |
   |    |       | USB IN |      |   |
   |    |    FLORA BLUEFRUIT    |   |
   |    | | MODE  |  | 3.3v  |  |   |
   |    | | GRND  |  | TX    -------+
   |    |      | RX    |        |
For the code itself, I basically have:
#include <Arduino.h>
#include <SPI.h>
#include "Adafruit_BLE.h"
#include "Adafruit_BluefruitLE_SPI.h"
#include "Adafruit_BluefruitLE_UART.h"
Adafruit_BluefruitLE_UART ble(Serial1, 12);
unsigned long previous = 0;
void setup(void) {
  while (!Serial) {
    delay(100);
  if (ble.begin(true)) {
    Serial.println("[bluetooth] ready");
  } else {
    Serial.println("[bluetooth] failed");
    while (true) {
      Serial.println("[bluetooth] failed boot, looping forever");
      delay(1000);
  if (ble.factoryReset()) {
    Serial.println("[bluetooth] reset success");
  } else {
    Serial.println("[bluetooth] reset failed");
  Serial.println("[bluetooth] ble ready, configuring");
  ble.info();
  ble.echo(false);
  ble.verbose(false);
void loop(void) {
  unsigned long current = millis();
  if (current - previous < 250) {
    return;
  previous = current;
  if (ble.isConnected() != true) {
    Serial.println("[bluetooth] not connected");
    return;
  Serial.println("[bluetooth] connection established");
  int message = ble.read();
  switch (message) {
    case -1:
      Serial.println("no message");
      break;
    default:
      Serial.println("has message");
      break;
  previous = current;
When I run this code, with that circuit in place, I see all of the logs from the setup function that I would expect:
[bluetooth] ready
Then, once the program enters the main loop, I do see:
Then, after connecting with the BluefruitConnect IOS app I see:
no message
The trouble I'm having is that it seems like the "read" call is never returning anything other than -1. Inside the BluefruitConnect IOS app I've tried both
1. sending text strings using the "UART" UI
2. clicking some of the buttons in the "Controller" -> "Control Pad" UI
Is there something obviously wrong with this setup?
Thank you!
P.S - By trade I've only ever worked with software on web applications, so my electrical engineering knowledge is very limited; I apologize if I'm not even making sense.
siz3thr33
Re: Gemma M0 + Flora Bluefruit
by siz3thr33 on Tue Nov 30, 2021 9:42 pm
Also I forgot to mention what I'm even trying to do (sorry!). As a proof-of-concept/learning-exercise, all I'm trying to do currently is be able to receive some kind of string sent over bluetooth (from the BluefruitConnect) and log it out to "Serial.println".
siz3thr33
by siz3thr33 on Wed Dec 01, 2021 10:42 am
also, I just noticed the diagram I posted had a little too much copy/paste, sorry. corrected:
   |    |       | USB IN |      |   |
   |    |         GEMMA         |   |
   |    |       | BATT   |      |   |
   |    |      | RX    |        |
siz3thr33
by siz3thr33 on Tue Dec 07, 2021 7:15 pm
I believe I figured out a few answers to my problem that are helpful:
1. The correct constructor to use when using either the flora or the gemma m0 is:
Adafruit_BluefruitLE_UART ble(Serial1, -1);
2. For the Gemma m0, the definition of "Serial1" comes from this definition, which does map RX to pin 2 and TX to pin 0 (matching the pinout diagram).
3. I believe I was misusing the bluefruit library, the data/command mode switching is pretty confusing. for example, checking isConnected after moving into data mode won't return the expected result as it does not switch itself into command mode before sending.
I'm still hoping to figure out a way to check the connection status during my main "loop", but have yet to figure that out.
siz3thr33
