I recently got the Adafruit Gemma v2 to use in a wearable project. However, although I followed every step in the 'Setting up gemma with Arduino' page, I keep getting an error. For the board I choose Adafruit Gemma and for the programmer; USBTinyISP. The error I get is below:
avrdude: Version 6.3-20190619
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : usb
Using Programmer : usbtiny
avrdude: usbdev_open(): Found USBtinyISP, bus:device: bus-0:\\.\libusb0-0001--0x1781-0x0c9f
AVR Part : ATtiny85
Chip Erase delay : 400000 us
PAGEL : P00
BS2 : P00
RESET disposition : possible i/o
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
An error occurred while uploading the sketch
eeprom 65 12 4 0 no 512 4 0 4000 4500 0xff 0xff
flash 65 6 32 0 yes 8192 64 128 30000 30000 0xff 0xff
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
Programmer Type : USBtiny
Description : USBtiny simple USB programmer, https://learn.adafruit.com/usbtinyisp
avrdude: programmer operation not supported
avrdude: Using SCK period of 10 usec
avrdude: error: usbtiny_transmit: libusb0-dll:err [control_msg] sending control message failed, win error: A device attached to the system is not functioning.
avrdude: initialization failed, rc=-1
this check.
avrdude done. Thank you.
Gemma v2 does not work in Arduino Sketch
- Ilayda
Re: Gemma v2 does not work in Arduino Sketch
NVM I figured it out :))
- Franklin97355
You can help others by telling us what you discovered.
- Ilayda
Yes of course, basically, I just had to turn my Bluetooth off because it read the serial port as COM 3 instead of USB. Although now my gemma works, I have a problem using the code I obtained from https://learn.adafruit.com/buzzing-mindfulness-bracelet. I assume my circuit is correct because the motor vibrates when I first plug into my PC and I just followed the circuit shown in the Adafruit page, however, once I upload the code to the Gemma nothing happens. Any help would be highly appreciated! Thanks in advance :)
The code is;
The code is;
const uint32_t // These may be the only lines you need to edit...
onTime = 2 * 1000L, // Vibration motor run time, in milliseconds
interval = 60 * 1000; // Time between reminders, in milliseconds
// It gets progressively geekier from here...
// Additional power savings can optionally be realized by disabling the
// power-on LED, either by desoldering or by cutting the trace from 3Vo
// on the component side of the board.
// This sketch spends nearly all its time in a low-power sleep state...
#include <avr/power.h>
#include <avr/sleep.h>
// The chip's 'watchdog timer' (WDT) is used to wake up the CPU when needed.
// WDT runs on its own 128 KHz clock source independent of main CPU clock.
// Uncalibrated -- it's "128 KHz-ish" -- thus not reliable for extended
// timekeeping. To compensate, immediately at startup the WDT is run for
// one maximum-duration cycle (about 8 seconds...ish) while keeping the CPU
// awake, the actual elapsed time is noted and used as a point of reference
// when calculating sleep times. Still quite sloppy -- the WDT only has a
// max resolution down to 16 ms -- this may drift up to 30 seconds per hour,
// but is an improvement over the 'raw' WDT clock and is adequate for this
// casual, non-medical, non-Mars-landing application. Alternatives would
// require keeping the CPU awake, draining the battery much quicker.
uint16_t maxSleepInterval; // Actual ms in '8-ish sec' WDT interval
volatile uint32_t sleepTime = 1; // Total milliseconds remaining in sleep
volatile uint16_t sleepInterval = 1; // ms to subtract in current WDT cycle
volatile uint8_t tablePos = 0; // Index into WDT configuration table
// Unused pins can be set to INPUT w/pullup -- most power-efficient state
pinMode(0, INPUT_PULLUP);
pinMode(2, INPUT_PULLUP);
// LED shenanigans. Rather that setting pin 1 to an output and using
// digitalWrite() to turn the LED on or off, the internal pull-up resistor
// (about 10K) is enabled or disabled, dimly lighting the LED with much
// less current.
pinMode(1, INPUT); // LED off to start
// AVR peripherals that are NEVER used by the sketch are disabled to save
// tiny bits of power. Some have side-effects, don't do this willy-nilly.
// If using analogWrite() to for different motor levels, timer 0 and/or 1
// must be enabled -- for power efficiency they could be turned off in the
// ubersleep() function and re-enabled on wake.
power_adc_disable(); // Knocks out analogRead()
power_timer1_disable(); // May knock out analogWrite()
power_usi_disable(); // Knocks out TinyWire library
DIDR0 = _BV(AIN1D) | _BV(AIN0D); // Digital input disable on analog pins
// Timer 0 isn't disabled yet...it's needed for one thing first...
// The aforementioned watchdog timer calibration...
uint32_t t = millis(); // Save start time
noInterrupts(); // Timing-critical...
MCUSR &= ~_BV(WDRF); // Watchdog reset flag
WDTCR = _BV(WDCE) | _BV(WDE); // WDT change enable
WDTCR = _BV(WDIE) | _BV(WDP3) | _BV(WDP0); // 8192-ish ms interval
interrupts();
while(sleepTime); // Wait for WDT
maxSleepInterval = millis() - t; // Actual ms elapsed
maxSleepInterval += 64; // Egyptian constant
power_timer0_disable(); // Knocks out millis(), delay(), analogWrite()
const uint32_t offTime = interval - onTime; // Duration motor is off, ms
ubersleep(offTime); // Delay while off
// WDT timer operates only in specific intervals based on a prescaler.
// CPU wakes on each interval, prescaler is adjusted as needed to pick off
// the longest setting possible on each pass, until requested milliseconds
// have elapsed.
const uint8_t cfg[] PROGMEM = { // WDT config bits for different intervals
_BV(WDIE) | _BV(WDP3) | _BV(WDP0), // ~8192 ms
_BV(WDIE) | _BV(WDP3) , // ~4096 ms
_BV(WDIE) | _BV(WDP2) | _BV(WDP1) | _BV(WDP0), // ~2048 ms
_BV(WDIE) | _BV(WDP2) | _BV(WDP1) , // ~1024 ms
_BV(WDIE) | _BV(WDP2) | _BV(WDP0), // ~512 ms
_BV(WDIE) | _BV(WDP2) , // ~256 ms
_BV(WDIE) | _BV(WDP1) | _BV(WDP0), // ~128 ms
_BV(WDIE) | _BV(WDP1) , // ~64 ms
_BV(WDIE) | _BV(WDP0), // ~32 ms
_BV(WDIE) // ~16 ms
}; // Remember, WDT clock is uncalibrated, times are "ish"
void ubersleep(uint32_t ms) {
if(ms == 0) return;
tablePos = 0; // Reset WDT config stuff to
sleepInterval = maxSleepInterval; // longest interval to start
configWDT(ms); // Set up for requested time
set_sleep_mode(SLEEP_MODE_PWR_DOWN); // Deepest sleep mode
sleep_enable();
while(sleepTime && (tablePos < sizeof(cfg))) sleep_mode();
noInterrupts(); // WDT off (timing critical)...
WDTCR = 0;
interrupts();
static void configWDT(uint32_t newTime) {
sleepTime = newTime; // Total sleep time remaining (ms)
// Find next longest WDT interval that fits within remaining time...
while(sleepInterval > newTime) {
sleepInterval /= 2; // Each is 1/2 previous
if(++tablePos >= sizeof(cfg)) return; // No shorter intervals
uint8_t bits = pgm_read_byte(&cfg[tablePos]); // WDT config bits for time
WDTCR = bits; // Interrupt + prescale
interrupts();
ISR(WDT_vect) { // Watchdog timeout interrupt
configWDT(sleepTime - sleepInterval); // Subtract, setup next cycle...
