Hi everyone,
I'd like to build the Florabrella.
Looking at the recommended battery (3.75V 2500mAh), I'm unsure:
How about the running time? 150 LEDs * 20mA = 3A. So the battery should be empty in less then in hour right?
What do you think of using an Arduino board and 4x NiMH cells as suggested here https://learn.adafruit.com/battery-powe ... -batteries?
These cells are readily-available, easy to recharge and can provide up to 4x 2500mAh. Sounds like a better option to me. Can I just add up the battery capacity to 10.000mAh?
Thank you for your suggestions!
Best regards, Simon
Florabrella battery running time
Re: Florabrella battery running time
Current draw depends a lot on how they are programmed. There are many techniques for extending the run-time of your portable Neopixel projects:How about the running time? 150 LEDs * 20mA = 3A. So the battery should be empty in less then in hour right?
https://learn.adafruit.com/sipping-power-with-neopixels
It doesn't work that way. Wired in series, you multiply the voltage, but the current capacity stays the same. You will get 4.8v @ 2500mAh.These cells are readily-available, easy to recharge and can provide up to 4x 2500mAh
If you want more capacity, you could switch to a higher capacity LiPo cell:
https://www.adafruit.com/product/354
https://www.adafruit.com/product/353
