Cheers!
I've been searching the webs for an example of using the 16 by 8 Matrix Backpack with a gemma. Basically the space invader project, but with a 16x8... I can't find it... I can only find code compatible with a larger trinket, through the LED Backpack examples. When running that example w the gemma it says not enough space...
Maybe someone knows how to edit the Space Invader project to work with a 16x8? I want to use it for scrolling text.
Thanks for any help!
Using Gemma with 16x8 Matrix Backpack
- adafruit_support_carter
Re: Using Gemma with 16x8 Matrix Backpack
What example are you running here?When running that example w the gemma it says not enough space...
The Space Invaders project is pretty optimized for the 8x8 display, making it tricky to port to 16x8. Or are you just wanting to scroll text?Maybe someone knows how to edit the Space Invader project to work with a 16x8? I want to use it for scrolling text.
- makeinspires
I'm running the example from the LED Backpack Library/Examples - I think it's mean for a feather...
Yes, just want to do scrolling text on it, basically a name tag!
The Gemma V2 (and the original Trinket) use a very small processor that doesn't have enough space to use the LED Backpack library. That's why the Space Invaders code does not use it and instead does stuff more directly, but as a result, potentially more difficult to understand.
You could try to use the Space Invaders code as an example of how to go about doing it, but a simpler option might be to upgrade to the newer M0 based Gemma:
https://www.adafruit.com/product/3501
which has enough space to use the LED Backpack library.
