Brain Machine Programming
Wearable electronics: boards, conductive materials, and projects from Adafruit!
caitlinsdad
Re: Brain Machine Programming
Post by caitlinsdad »
If it was from the Adafruit kit, the chip should have been preprogrammed and ready to use. https://learn.adafruit.com/brain-machine/overview
caitlinsdad
The chip used is an attiny25 so you would need to be set up for bare AVR microcontroller chip programming. As a minimum, I would think you need the FTDI interface wired up to the chip to communicate with your computer and then the required software to be able to program the chip. This may delve deeper than the usual Arduino type programming and need more advanced skills if you attempt to reprogram what you have. Good luck.
Return to “Wearables”
